EGR blockoff/delete running Spartan tune - Ford Powerstroke Diesel Forum
post #1 of 5 Old 10-29-2013, 02:37 PM Thread Starter
LORD OF WAR
nelson1each's Avatar
Feedback Score: 4 reviews
Looking around at the different threads here seems to be a lot more info when it comes to other than Spartan tunes and stuff like egr block offs or deletes. I had read a thread last night about after blocking off the egr (which I had already done) there are 2 orange plugs that need to be removed. 1 on the egr and one on some flutter valve near the radiator on the right side(looking at the truck). I disconnected both of them and my truck ran weak. No check engine lights or anything but would not boost any higher than about 15-16 and was just slow. Called Spartan. Apparantly the disconnecting of these two plugs does not apply to those that are running Spartan tunes and disconnecting them will cause your truck to go into a reduced power mode...specifically its the flutter valve plug that caused this. I plugged them both back in and im running strong again. I guess Spartan's tunes there stuff a bit different than H&S when it comes to the egr.
Lastly I have the Sinister EGR delete kit, have not installed yet but will sooner or later. I found out that without the EGR Coolant tube from street diesel performance those with a Spartan tune will get a code. This tube is needed as the Spartan tuner monitors coolant temp and this coolant tube is required to install a sensor that is removed from the EGR after removal. When I get around to doing the install I will post up a thread with some pics and a review...but for not just wanted to pass along the info for those that are Spartan tuned and searching for information on this stuff.
87,96,04 F150 gone
2011 F250 6.7L SC Lariat 4x4
"The War Wagon"
5" Flo Pro w/muffler, SDP downpipe, Sinister EGR delete, S&B intake, H&S mini maxx w/ SPE HotX, H&S intercooler pipe, MPD CCV Mod, Top Gun Customz 6" Lift, TGC dual steering stabilizer w/ night hawk shocks, TGC ladder bars, Night hawk 2.65 resi shocks, BMF rehab 20x9 rims with 5" backspacing (0 offset), Nitto Trail Grappler 37x12.50x20 tires, SSBC calipers w/Big Bite rotors front & rear, SPE metal oil pan upgrade & full diff lock, Mag-hytech dif cover, Deezee headache rack, Bushwacker fender flares & shocker 540 train horns.
nelson1each is offline
post #2 of 5 Old 10-29-2013, 10:52 PM
Cratos's Avatar
what egts are you seeing at the block off plate after the delete?
2012 F-250 4X4 FX4, SCLB, 3:55's , Camper & Tow package, air lift bags and pump, Edge insight. Dark Pearl Blue.
Cratos is offline
post #3 of 5 Old 10-30-2013, 02:53 PM Thread Starter
LORD OF WAR
400ish at idle...600ish normal driving...800-900ish if I floor it
87,96,04 F150 gone
"The War Wagon"
post #4 of 5 Old 10-31-2013, 02:05 PM
Anth's Avatar
When you do the pipe from street diesel you might remove the grill and the passenger side headlight it might help you with getting to that side of the radiator.
2013 Platinum White, Dura Flaps, B&W turnover,
mpd s365 turbo kit, tuned by craig at mpd, no limit egr delete, amp steps, icon leveling kit, ouo traction bars, 20x10 bmf wheels, 35 toyo mt, bushwacker fender flares, painted to match headlights with projectors, absolute performance ccv kit.
Anth is offline
post #5 of 5 Old 10-31-2013, 02:28 PM Thread Starter
LORD OF WAR
Thanks for the heads up...I plan on tackling this project tomorrow. I will post up some pics/review of how the project goes.
87,96,04 F150 gone
"The War Wagon"
