6.7 Exhaust - Ford Powerstroke Diesel Forum
post #1 of 7 Old 09-26-2013, 06:56 PM Thread Starter
6.7 Exhaust
Looking to replace the goofy looking exhaust on my new 6.7. What options are there and what looks the best? Thanks
w-r-g is offline
post #2 of 7 Old 09-26-2013, 07:04 PM
WoodBoy's Avatar
Are you looking for a dpf back exhaust? or full exhaust?
2010 CC/SB FX4 Lariat.. Tuned By Eric@IDP and Matt@Gearhead
Thinking about getting rid of the stock 6.7 turbo?
Check this out... and research before buying
WoodBoy is offline
post #3 of 7 Old 09-26-2013, 07:12 PM Thread Starter
Yeah DPF back for sure , not going to mess with emissions on this one. I just do not like the look of the duel type exhaust and wondering what the best alternative is. Thanks
w-r-g is offline
post #4 of 7 Old 09-26-2013, 07:56 PM
Hellobatman's Avatar
I've been looking at pulling the trigger on the MBRP 5". Look around on here, you'll find a few threads with some pics of trucks that have it. Looks much better than stock!
2013 F-250 Lariat FX4, 6.7 Scorpion, All the bells and whistles!
Hellobatman is offline
post #5 of 7 Old 09-27-2013, 03:21 AM Thread Starter
Yeah I have used MBRP quite a few times and like it. You think it is worth going with all the pipes from filter back or just getting rid of the duel ford pipes and putting on the MBRP tip if that fits?
w-r-g is offline
post #6 of 7 Old 09-27-2013, 06:44 AM
You'd have to cut the stock dual tips off, then probably weld a little pipe extension on in order to get your tip out far enough. If you look on the stockers, you'll notice to take them off would be pretty far in from the fender line. I'm sure it can be done, personally, I think the whole dpf back system looks good and if you ever have to go back to stock you can put the stock tips back on. Never any sign of hacking or welding.
Check auto anything. I regularly get 15% off emails that drop the kit by ~$50 and there's currently a $50 rebate through mbrp.
post #7 of 7 Old 09-27-2013, 08:10 AM
WoodBoy's Avatar
Check Performance Truck Products or Rudys Diesel.
WoodBoy is offline
