h&s tuner - Ford Powerstroke Diesel Forum
post #1 of 14 Old 09-14-2013, 01:54 PM Thread Starter
h&s tuner
my brother brought his 2012 f-250 over to the house his morning. the pyro gauge on his h&s minituner is just reading 32 degrees. let the truck set for a few hours, started it up as soon as the gauges started reading the pyro jumped right to 32 degrees again. took it for a ride, ran it hard and just cruised around and the pyro stays locked on 32 degrees. does anyone know what could be causing the problem? the truck still runs great with know problems other than he said the his fuel milage has dropped around 3 mpg. any input would be appreciated
skewby is offline
post #2 of 14 Old 09-14-2013, 02:18 PM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
Pyro manulfuction doesn't have anything to do with his mpg loss. I'd contact H&S and see what they say, how old is the monitor/tuner?
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
post #3 of 14 Old 09-14-2013, 02:32 PM
BIG Laing's Avatar
In the settings on the tuner, make sure you have the right pyrometer source selected.
Did your brother delete his DPF? Only way your MPG would drop is if he is plugging up his DPF with dpf off tunes.
2013 Lariat Eco-Boost F150 Super Crew 4x4 20K Miles. Max-Tow 3.73's, luxury package. Amp Steps, Raceline Raptor Wheels, Bak-Flip, and much more.
BIG Laing is offline
post #4 of 14 Old 09-14-2013, 04:45 PM
What he said
2012 F350, 6.7L Diesel, 4x4, SRW, Crew Cab, Short Box, Loaded, Ingot Silver
Detroit Truetrac, Icon leveling springs, steering damper mounts, King reservoir shocks and steering damper, Ultra Predator 22x10 and Nitto Terra 325/50R22 (35"s), H&S Minimaxx & Gearhead, aFe 5" SS w/ muffler, Leer XL, LineX, Titan 50gal, Airlift bags and wireless.
TrickTruck is offline
post #5 of 14 Old 09-14-2013, 06:31 PM
2013F250Tank's Avatar
Has it read over 200* or shot to 2222* since it was installed?
13 F250 Lariat CC SB 3.31 EL axle w/SPE full lock module, Ultimate Interior,
H&S Big Single 64mm NON VGT Turbo Kit, Cast manifolds, NON Cobra downpipe, Mini MAxx w/H&S stock fuel tune
Down Pipe back 304T 4" Diamond Eye, AFE stage II intake, front 4 link,
Road Armor bumpers front/rear. N Fab nerf steps. 20" American Force w/Trxus 33",
Dura flaps, Air Lift rear bags, 34k+ miles, Stage 3 traction block bars.
2012 F250 TOTALED.
Civilian Contractor Airforce 2+ years Asscrackistan.
2013F250Tank is offline
post #6 of 14 Old 09-14-2013, 06:53 PM Thread Starter
the tuner is 14-16 months old. he said that one day the pyro got over 2000 and the truck started running funny, like it was running out of fuel, he pulled over turned it off and restarted the truck and ever since it has only read 32 degrees
skewby is offline
post #7 of 14 Old 09-14-2013, 07:15 PM Thread Starter
he said it did go to 2222 when it started acting funny. but all was fine after he turned it off and restarted
skewby is offline
post #8 of 14 Old 09-15-2013, 04:53 AM
Reason i ask different tunes use different temp probs. Example. Powerlabs uses the EGR prob while SPE uses the DPF probe. I switched to SPEs' tune didnt change to DPF prob and mine would read 32* or sky rocket to 2222+.
2012 F250 TOTALED.
post #9 of 14 Old 09-15-2013, 05:47 AM Thread Starter
tank what is odd is the fact that the truck has had all this work done to it (tuner, exhaust, exh filter delete) since its had 10k miles. the turbo went out and it was replaced by the dealer all was fine for around 3k miles then 32 pops up in the pyro. as far i know his h&s minimax was a direct plug into the factory harness
skewby is offline
post #10 of 14 Old 09-15-2013, 11:55 AM
Quoted: 8 Post(s)
ARPs w/OEM Gaskets
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
