13 Platinum Ready to Install DPF & EGR Delete, EGT Kit, & Intake! Advice Needed! - Ford Powerstroke Diesel Forum
post #1 of 15 Old 07-24-2013, 06:15 AM Thread Starter
DINOONE's Avatar
Getting ready to empty out my garage from all the parts I have been storing up to put on my truck. I have a MBRP DPF Delete 5" Exhaust, Sinister EGR Delete, S&B Intake Kit, H&S Mini Maxx Tuner, and the H&S EGT Kit.
My big question is where do I start? I have searched and everyone says something different this is what I have gathered from my research just need some confirmation from the guys that have done this:
1. Install H&S Mini Maxx Off Road Tune
2. Install DPF Delete
3. Install EGR Delete
4. Install S&B Intake
5. Install EGT KIT
6. Modify Pyro Settings in Mini Maxx
Am I on the right track on do I need to do something different? I having a shop do the install because I don't have the time.
DINOONE is offline
post #2 of 15 Old 07-24-2013, 10:05 AM
travisH3's Avatar
Quoted: 2 Post(s)
Feedback Score: 13 reviews
i would tune the truck and start it one time with dpf still on. after you know it starts then remove the dpf and take it for a drive. make sure the tuning goes through before you start going any deeper. then egr delete, intake, and egt pyro kit next. you can do it the way you have listed but i just like to make sure the tune goes on the truck before i start modifying too deeply for it to be easily returned to stock so that you dont risk totally blowing the warranty.
T-rav
2010 F350 6.4-
s467 MPD single kit, H&S Jesse Byall tuning, No limit IC piping and intake,mishimoto intercooler, MPD billet CCV/oil filler, FASS with sump, SOTA A.W.O.L. polished wheels, toyo rt tires, RED Newton traction bars, oem projector retrofit and a bunch of LED lights LOL
Holderdown Performance #teamHDP
OUR FLEET: 2015 f450, 2014 Platinum F350, 2012 F450 6.7, 2010 F350 6.4, 2005 F350 6.0, 04 F450 6.0
travisH3 is offline
post #3 of 15 Old 07-25-2013, 02:04 AM
Keep in mind, there is no need to a EGT kit. Alls you need do is uninstall of the othe EGT probes from the facotry DPF and install it into the EGR block-off plate that has the bung for it. Then plug it into the corresponding plug that on the front side of the motor, and wah-la, you have EGT gauge on source 1 on H&S pyro source select.
'13 F250 CCSB Black/Black: Carli Starter & Stabilizer, Minimaxx, S&B intake, 5" FloPro, egr blocker, BMF Rehabs, Toyo AT IIs, Titan 50gl Tank, Amp steps, Blacked Out Tails/3rd/Markers, Full Custom Sound
highdrum is offline
post #4 of 15 Old 07-25-2013, 03:12 AM
I would install the minimax first (dpf on) and make sure that goes smoothly before doing the labor on the hard parts. There have been some failures on the fist download that bricks the factory computer. A small percentage, but it happens. Once you have it running on H&S drive it around a bit and make sure it's OK, then do the hardparts.
You do not need a H&S pyro, there are like 4 of them in the factory exhaust you can use.
2012 F350, 6.7L Diesel, 4x4, SRW, Crew Cab, Short Box, Loaded, Ingot Silver
Detroit Truetrac, Icon leveling springs, steering damper mounts, King reservoir shocks and steering damper, Ultra Predator 22x10 and Nitto Terra 325/50R22 (35"s), H&S Minimaxx & Gearhead, aFe 5" SS w/ muffler, Leer XL, LineX, Titan 50gal, Airlift bags and wireless.
TrickTruck is offline
post #5 of 15 Old 07-25-2013, 04:59 AM Thread Starter
DINOONE's Avatar
So it's okay to drive around for a bit with the truck tuned and DPF still on? Sounds like plan. Hoping to get the truck into the shop sometime next week!
Thanks guys.
I ordered the H&S EGT Plate so I could use the factory stuff like everyone suggested.
Sent from AutoGuide.com App
DINOONE is offline
post #6 of 15 Old 07-25-2013, 05:52 PM
Thanks guys.
He is saying to use dpf on tune first. Don't tune for dpf off and drive around with the dpf still installed. Your truck will throw a code and shut down.
2011 F-350 CCSB
powerstroke43 is offline
post #7 of 15 Old 07-25-2013, 07:56 PM Thread Starter
DINOONE's Avatar
Geese thanks for the clarification on that!
DINOONE is offline
post #8 of 15 Old 07-26-2013, 06:16 AM
So y'all dont think the egr delete is necessary? It can't hurt as keeping the hot exhaust temps out of the intake is a good thing. Or are y'all saying there is a better way to do it without buying the kit. I know it's turned off w the tuner.
fuzzielightning is offline
post #9 of 15 Old 07-26-2013, 08:22 AM
travisH3's Avatar
Quoted: 2 Post(s)
No I tune dpf off. Start the truck dpf is still on to just make sure the tune takes and once I know it starts I remove dpf. Just don't drive it around like that. Just do it to make sure it starts.
T-rav
2010 F350 6.4-
travisH3 is offline
post #10 of 15 Old 07-26-2013, 12:21 PM
When you say egt kit do you mean the block off plates or just the h&s pyro? Since you bought the egr delete you don't need the h&s pyro or the block off plates. If you want to use the egr block off plates you don't need the h&s pyro either. You use one pyro from the exhaust.
2011 F-350 CCSB
