Re gearing! - Ford Powerstroke Diesel Forum
post #1 of 25 Old 07-16-2013, 06:49 PM Thread Starter
Re gearing!
12 inch bulletproof lift on the way! Running 40 inch M16s, has anyone re geared their trucks yet going with bigger tires? And what gears did y'all use? And if anyone is out there on 40s what kind of mpg are you seeing? Appreciate the help!
CoalTrain99 is offline
post #2 of 25 Old 07-16-2013, 06:57 PM
Most go with 4.56s or 4.88s when running 40s. I can't give you any mileage claims with that big of tires, but I doubt it'll be anything to brag about.
Moto2four is offline
post #3 of 25 Old 07-16-2013, 08:36 PM
WoodBoy's Avatar
I don't see the need to go to 4.56 or 4.88 with the 6R tranny. 4.10 or maybe 4.30
2010 CC/SB FX4 Lariat.. Tuned By Eric@IDP and Matt@Gearhead
Thinking about getting rid of the stock 6.7 turbo?
Check this out... and research before buying
WoodBoy is offline
post #4 of 25 Old 07-16-2013, 09:08 PM
BIG Laing's Avatar
OP what gears you have now?
2013 Lariat Eco-Boost F150 Super Crew 4x4 20K Miles. Max-Tow 3.73's, luxury package. Amp Steps, Raceline Raptor Wheels, Bak-Flip, and much more.
BIG Laing is offline
post #5 of 25 Old 07-16-2013, 09:34 PM
I have 40's on my 6.7 and also had em on my 6.4, the 6.4 deleted with 5" exhaust and spartan got about 17 highway and 14 city hand calculated. The 6.7 I have now has a h&s tuner with the factory exhaust and I get about 11 all the time. The question is what are you going to be doing with the truck after the lift. I don't tow heavy but I have 3.55's and it pulls like a freight train so I don't know if gears are really necessary unless you are going to be pulling super heavy. If I were you I would put the lift and tires on and see how it does without gears before pulling the trigger. Also going that big, if you plan on using the truck in 4x4 much at all you will need to fix the front driveline angles. I couldn't ever get the m16's to balance worth a crap on 24" wheels so I went with 20"s and toys on this truck and it rides alot better than the 6.4 did.
Chaas75 is offline
post #6 of 25 Old 07-17-2013, 04:07 PM Thread Starter
I appreciate the help! Most likely going with 4.30s for the gears if I do end up doing them. As far as towing nothing too heavy my Rzr on a lowboy.. Other than that a pavement queen that will see the beach a few times. Mainly wanting to change the gears for a little more mileage sake, I know the truck has plenty of power I have a mini maxx with the snyder hot tune and 5 inch exhaust
post #7 of 25 Old 07-17-2013, 06:28 PM
brandonlee0034's Avatar
Changing the gears will drop your fuel economy. I have 40's on mine and get about 15mpg average, mostly consisting of city travel. I've towed my boat about 5,000lbs with the stock 3:55 gears and had no trouble. If your wanting the best fuel economy then gears is not what you want to do because it'll just raise the rpm's decreasing mpg.
2011 F250 6.7
Stock...?
brandonlee0034 is offline
post #8 of 25 Old 07-17-2013, 07:38 PM
Randy_270's Avatar
Quoted: 2 Post(s)
That is true to a point. Your truck has to work wayyyy harder then a say a truck with 4:30s to accelerate. So with all the extra work it has to do to accelerate it'll use more fuel. Also if you live in a hilly area regearing will increase your mileage because your truck won't use as much boost to maintain speed. And if what you say about lower rpm being better for mileage you should get better mileage than a truck with stock tires which I can say you don't lol. So to the OP I'd say go 4.30s and your truck and tranny will thank you. Also if you don't get any mileage out of it you will have a lot more power(but I'm pretty positive you will increase mileage)
2011 F350 Lariat FX4, CCSB, 6.7, 3.55s, 325/65R18 Duratracs, Carli 4.5" Pintop, Flo-Pro, S&B intake, H&S w/ SPE tuning.
2011 Explorer Limited 4WD on 17x7.5s Core Racing Diablo 2s with 245/70R17 Duratracs
Randy_270 is offline
post #9 of 25 Old 07-17-2013, 07:54 PM
BIG Laing's Avatar
I think 3.55's and 4.30's are both bad choices with a 40" tire. 3.73's with the 6R140 is plenty, and 4.10's would be overkill as the op has stated its a pavement queen.
post #10 of 25 Old 07-17-2013, 08:06 PM
Randy_270's Avatar
Quoted: 2 Post(s)
Imo I don't think going from 3.55 to 3.73 would do enough to justify the cost. 4.30s are going to give you a large power boost, close to stock. I've noticed power loss with 35s so I couldn't imagine 40s, so if your gonna get crappy fuel mileage you might aswell have lots of power
