Tuning and Turbo Questions - Ford Powerstroke Diesel Forum
post #1 of 9 Old 07-16-2013, 04:27 PM Thread Starter
How many trucks are running tuning on the stock turbo? How many have had turbo trouble?
How many have a stock truck with turbo failure?
What I am getting at is how/why would deleting restrictive Emmisions equipment kill a stock turbo (rods another story due to the increase in boost and ramp up timing)?
I will end up with an aftermarket single but I'm just not entirely grasping why stock turbos (driven normally) would die from tuning...........
Thoughts
PlatinumScorpion is offline
post #2 of 9 Old 07-16-2013, 05:12 PM
BIG Laing's Avatar
Originally Posted by PlatinumScorpion View Post
How many trucks are running tuning on the stock turbo? Hundreds of thousands
What I am getting at is how/why would deleting restrictive Emmisions equipment kill a stock turbo (rods another story due to the increase in boost and ramp up timing)? It sounds like you answered yourself here... Increased boost, more RPM, More heat, ect...
I will end up with an aftermarket single but I'm just not entirely grasping why stock turbos (driven normally) would die from tuning........... You hear the few horror stories, but hundreds of thousands of stock turbos are fine. (knock knock)
Thoughts
Thought it would be easier to put my opinion above ^^^
2013 Lariat Eco-Boost F150 Super Crew 4x4 20K Miles. Max-Tow 3.73's, luxury package. Amp Steps, Raceline Raptor Wheels, Bak-Flip, and much more.
BIG Laing is offline
post #3 of 9 Old 07-16-2013, 05:47 PM
WoodBoy's Avatar
As stated, there are thousands running tuning on stock turbo. Most turbo failures are C&C models. And the tuning has came a long way to keep the turbo in its range to prevent failures
2010 CC/SB FX4 Lariat.. Tuned By Eric@IDP and Matt@Gearhead
Thinking about getting rid of the stock 6.7 turbo?
Check this out... and research before buying
WoodBoy is offline
post #4 of 9 Old 07-16-2013, 06:03 PM Thread Starter
What was the latest and greatest H and S High Sulfur firmware?
post #5 of 9 Old 07-16-2013, 06:54 PM
2013F250Tank's Avatar
tuning for H&S alone has gone from 34psi to 24-26 psi max on Performance tune.
13 F250 Lariat CC SB 3.31 EL axle w/SPE full lock module, Ultimate Interior,
H&S Big Single 64mm NON VGT Turbo Kit, Cast manifolds, NON Cobra downpipe, Mini MAxx w/H&S stock fuel tune
Down Pipe back 304T 4" Diamond Eye, AFE stage II intake, front 4 link,
Road Armor bumpers front/rear. N Fab nerf steps. 20" American Force w/Trxus 33",
Dura flaps, Air Lift rear bags, 34k+ miles, Stage 3 traction block bars.
2012 F250 TOTALED.
Civilian Contractor Airforce 2+ years Asscrackistan.
2013F250Tank is offline
post #6 of 9 Old 07-16-2013, 07:35 PM
WoodBoy's Avatar
Just a change in names...
WoodBoy is offline
post #7 of 9 Old 07-16-2013, 07:40 PM
I_AM_RP3's Avatar
Forgive my ignorance, but what is a C&C model? Seen it referenced a few times but I can't figure it out.
I_AM_RP3 is offline
post #8 of 9 Old 07-16-2013, 07:50 PM
Quoted: 2 Post(s)
Cab and chassis
2012 F250 CCSB 6.7 (3.73 gears) H&S Minimaxx (My own tuning), H&S 64mm turbo kit, H&S Dual Fueler, H&S Low Pressure Fuel System, H&S CCV delete, No Limit s2 Intake, PMF 3-link, PMF traction bars, Fox 2.0s, Icon 2.5" coils, Platinum 20s w/ 295/65 toyo at2s, Airlift bags and wireless controller, TFI 50gal, rollX, AMPboards,
jcain is offline
post #9 of 9 Old 07-16-2013, 08:10 PM
I_AM_RP3's Avatar
Who knew... thanks
I_AM_RP3 is offline
