Pulled the trigger - Ford Powerstroke Diesel Forum
post #1 of 10 Old 06-27-2013, 10:30 AM Thread Starter
Crazyfrog's Avatar
Pulled the trigger
Well, I guess I just cant leave well enough alone. I pulled the trigger and ordered all my parts for Delete. Using a mini max.
The question I have is about the EGR. What is the benefit / Pro's & Cons of getting block off plates, or just unhooking the wires?
Parts should be in next week, then I'll just need to get a free day to install.
2012 CCSB 4X4
XLT - 3:55 6.7
Mini Max-S&B intake
305/65/18 Falkens
Weather guard toolbox
Crazyfrog is offline
post #2 of 10 Old 06-27-2013, 11:28 AM
Just leaving it in place is best.
Very little benefit other than space and looks.
Fairly big job to take off and put in if you need warranty work.
cfd_shop is offline
post #3 of 10 Old 06-27-2013, 11:38 AM
I would just do the blocker plates, that way you can have the EGT probe to get pre-turbo temps. Its a task to take out the whole cooler, I will wait for that a while down the road, only 700 miles on mine so far.
'13 F250 CCSB Black/Black: Carli Starter & Stabilizer, Minimaxx, S&B intake, 5" FloPro, egr blocker, BMF Rehabs, Toyo AT IIs, Titan 50gl Tank, Amp steps, Blacked Out Tails/3rd/Markers, Full Custom Sound
highdrum is offline
post #4 of 10 Old 06-27-2013, 06:42 PM
Quoted: 2 Post(s)
Took less than 2 hours to remove egr. Less crap to break or leak now.
2012 F250 CCSB 6.7 (3.73 gears) H&S Minimaxx (My own tuning), H&S 64mm turbo kit, H&S Dual Fueler, H&S Low Pressure Fuel System, H&S CCV delete, No Limit s2 Intake, PMF 3-link, PMF traction bars, Fox 2.0s, Icon 2.5" coils, Platinum 20s w/ 295/65 toyo at2s, Airlift bags and wireless controller, TFI 50gal, rollX, AMPboards,
jcain is offline
post #5 of 10 Old 07-04-2013, 06:01 AM Thread Starter
Crazyfrog's Avatar
Ok, got everything on. Got a question or 2.
If I set pyro to H&S, do I need to do anything else with pyro settings?
What exactly is defuel? And if I set pyro to h&s, does that override defuel or is it something to set myself?
If I don't have blocker plates and probe, I still have no way to watch egt's?
Thanks in advance for your answers!
Edit: by the way, this thing is like a different truck! I'm gonna have to learn to keep my foot out of it!
2012 CCSB 4X4
XLT - 3:55 6.7
Mini Max-S&B intake
305/65/18 Falkens
post #6 of 10 Old 07-04-2013, 06:46 AM
lilman-bigstroke's Avatar
As far as my EGR goes i am using the blocker plates and unplugging from the cooler. Doesn't hurt anything to leave it there and ALOT less headache than removing it.
CrazyFrog i too got my stuff in just like your setup. Anxious to see how it does
2011 F250 FX4 Lariat
4.5" rough country/Dual steering Stabilizers
35" Toyo MT's...20x10 Fuel Mavericks coming soon -24
lilman-bigstroke is offline
post #7 of 10 Old 10-19-2013, 04:33 AM
Send a message via Skype™ to bikepsych
Crazyfrog, did you ever get an answer to your questions about the DPF cleaning override? What else did you have to do to enable it to do that?
BG
bikepsych is offline
post #8 of 10 Old 10-21-2013, 05:15 AM Thread Starter
Crazyfrog's Avatar
BG
I'm not sure I know what your question is.
The DPF is no longer there, and the tuner is set to understand that.
2012 CCSB 4X4
XLT - 3:55 6.7
Mini Max-S&B intake
305/65/18 Falkens
post #9 of 10 Old 10-21-2013, 07:43 AM
That answered it perfectly. Did your fuel MPG change? How difficult was it to delete the DPF?
BG
post #10 of 10 Old 10-21-2013, 11:36 AM Thread Starter
Crazyfrog's Avatar
My overall average went up about 1.5 mpg, due to not regenerating. Its not hard to do, but heavy and awkward. Have a friend help that is mechanically inclined.
2012 CCSB 4X4
XLT - 3:55 6.7
Mini Max-S&B intake
305/65/18 Falkens
