EGR Delete - yes or no? - Ford Powerstroke Diesel Forum
post #1 of 2 Old 06-12-2013, 05:55 PM Thread Starter
AggieStroke's Avatar
So the truck is in the shop getting a head gasket job done and I am thinking, while it is in there, why not go ahead and delete the EGR on it? Good idea right? Well, talking to the guys at Alligator Performance, they said that the EGR acts as a wastegate somewhat to help reduce drive pressure cause FoMoCo didn't include one in our $65k trucks...so now I am torn on whether to delete and have accurate pre-turbo egt readings, or leave on there to help from lifting the heads again when pulling a 9000 lb trailer with 15000lbs of oilfield equipment on it through the Rockies ... any input would be greatly appreciated.
Sent from AutoGuide.com App
2012
F350 FX4 Crew Cab Dually Lariat
Ranchhand Front w/Rigid LED's
MiniMax (usually mild only)
Straight pipe & EGR Blocked
Firestone air bags and a B&W to haul with
100 gal gravity feed tank for longer legs
Gig 'Em Aggies
AggieStroke is offline
post #2 of 2 Old 06-12-2013, 06:28 PM
The turbo has a built in waste gate. In fact, if your trucks deleted, the H&S turns the EGR system off.
alynnsnyder is offline
