Turbo Sound - Ford Powerstroke Diesel Forum
post #1 of 10 Old 06-08-2013, 11:31 PM Thread Starter
Turbo Sound
I have a H&S Tuner and I'm DPF deleted with EGR disconnected. Also running an S&B CAI. Right after I installed this set up my turbo has more of a screech sound then a nice whistle while spooling up. Mostly between 5-15psi. That's with normal driving. Anyone else have a whistle that's closer to a screech noise? Its only on acceleration, performance has been great when I want it but the screech is annoying.
Power is nice, love the exhaust note and diesel smell. My mpg has gone up by 3 on the hiway. I don't flog my truck at all, I did this for better mileage and it is my work truck so it needs to be reliable.
The main reason I went with a tune to start with was because FORD in all their cheapness wouldn't replace my DEF pump that failed,,,not covered under my drivetrain warranty(bumper to bumper is expired). So I decided they weren't getting anymore of my money and I would just tune out that garbage.
I would be worried my turbo was about to fail if this screeching started weeks after the mods were done, but it was immediately after that it started. Since I own an early 2011 the turbos aren't great to begin with, maybe I should be looking for an aftermarket turbo soon to cure that noise.
Rodzilla is offline
post #2 of 10 Old 06-09-2013, 09:12 AM
I have the same parts as you and the same screech is heard by all. Basically it seems to be the wastegate opening and dumping excess pressure into the exhaust all at once, and since we're running straight pipes it sounds bad.
FYI
Friday night I blew up my turbo. I'll be calling a lot of people Monday to confirm and start seeing what I can do to fix it better. Probably too much boost, I set my defuel level at 31 psi.
FORDTUF1 is offline
post #3 of 10 Old 06-09-2013, 08:18 PM Thread Starter
I hear the big woosh that's very noticeable when the boost bleeds off, I assumed that's the wastegate and it sounds cool. But this screetch I hear while spooling up is horrid. Makes me worry slightly, especially with the 2011 turbo. Im going to order a confederate real soon, for some piece of mind. Cheers
Rodzilla is offline
post #4 of 10 Old 06-09-2013, 08:28 PM
Yeah it's a Turbo Diesel
mts678's Avatar
Quoted: 7 Post(s)
Feedback Score: 12 reviews
The swoosh is normal. The stock airbox muffles it and u don't hear it
Sent from AutoGuide.com App
Marshall
2002 F250 7.3L CCSB 4WD
Tinted | Focal speakers & 12" Kicker | CTS Insight | CNC fuel line kit | PIS 200/80's | KC38R | Nathan P3 train horns & Onboard Air
mts678 is offline
post #5 of 10 Old 06-09-2013, 09:37 PM Thread Starter
Ya,,,its the screech I'm concerned about.
Rodzilla is offline
post #6 of 10 Old 06-09-2013, 10:09 PM
mts678's Avatar
Quoted: 7 Post(s)
Can u record a video and post up the YouTube link so we can hear it?
Marshall
mts678 is offline
post #7 of 10 Old 06-11-2013, 12:09 AM Thread Starter
I will try in the next day or two
Rodzilla is offline
post #8 of 10 Old 08-14-2013, 10:43 AM Thread Starter
Forgot to post a reply about what I found. Turned out it was the metal gasket burnt out under the EGR block off plate, it was making the screetching noise as a small amount of exhaust came out into engine compartment. After breaking off bolts in the manifold while removing EGR crossover I guess I was a bit hesitant to tighten plate as much as I should have.
New gasket and bolts tightened good, problem solved.
Rodzilla is offline
post #9 of 10 Old 08-14-2013, 04:02 PM
Thanks for the update.
2011 F350 4X4 CCSB SRW, King Ranch, 3.55, Mini Maxx, 4 inch exhaust, egr gone, Confederate Diesel turbo kit with a S363 and 0.91 twin scroll turbine housing, and stock air filter.
DirtBikePilot is offline
post #10 of 10 Old 08-15-2013, 09:44 AM
Quoted: 2 Post(s)
My truck has done it since 4000 miles no problems yet!
2012 F-250 6.7L 4x4 Lariat CCSB, Titan 51gal, BDS 4" kit with Fox Shox, Toyo AT II 35/12.50R20, Ranch Hands front and rear
2007 F-150 King Ranch 4x4 2" Autospring, Bilstein 5100s on all four corners. Nitto A/T 285s.
2005 Chevy Tahoe 5.3l 2WD
wreedPS is offline
