DPF delete? - Ford Powerstroke Diesel Forum
post #1 of 16 Old 05-10-2013, 06:11 AM Thread Starter
DPF delete?
Good morning guys. I'm new to the forum & new to the diesel scene as well. Just purchased a '13 F250 Platinum edition & I love it so far. I keep coming across he term DPF delete & I have no idea of what that is. Does anyone mind explaining it to me? What are the pros & cons to this? Also, what are the benefits of having your vehicle tuned? Thanks in advance & I apologize for my ignorance.
MHORTON79 is offline
post #2 of 16 Old 05-10-2013, 06:18 AM
RTRBURN's Avatar
DPF= Diesel Particulate Filter...AKA Big Ole Cigarette Filter in your Exhaust. Look under the Passenger side...You Can't miss it.
The DPF captures all the Soot/Black Smoke. Once the DPF starts to get clogged, it goes through a process injecting DEF Fluid into the exhaust system and does a High Temp cleaning you could say of the exhaust system. There are plenty of videos that explain the whole process along with the pros and cons...biggest Con...Voided warranty.
2011 Silver F250 Lariat CCSB 4x4 6.7 H&S Deleted (mine)
2012 Burgundy F350 Lariat CCSB FX4 6.7 (wifes)
RTRBURN is offline
post #3 of 16 Old 05-10-2013, 06:29 AM Thread Starter
I'm assuming that this is what's happening when my info screen says its cleaning the exhaust filter?
post #4 of 16 Old 05-10-2013, 01:54 PM
BIG Laing's Avatar
DEF is not injected for regens. Diesel fuel is what burns off soot in the DPF during regens.
DEF is part of the selective catalyst system. It works in conjunction with the EGR to reduce NOx. DEF is only injected when the computer tells it.
2013 Lariat Eco-Boost F150 Super Crew 4x4 20K Miles. Max-Tow 3.73's, luxury package. Amp Steps, Raceline Raptor Wheels, Bak-Flip, and much more.
BIG Laing is offline
post #5 of 16 Old 05-10-2013, 01:57 PM
BIG Laing's Avatar
You got it. And I am assuming you have seen your lie-o-meter drop down to 10mpg during the regen?
post #6 of 16 Old 05-10-2013, 02:39 PM Thread Starter
I haven't seen it drop to that degree. I'm actually averaged around 16-17 mpg so far. I have a tad over 1100 miles so far.
I've read somewhere that a delete on the newer 6.7s isn't as beneficial as it is on the 6.4s. Is this true? Also, I still haven't been able to find out what the pros are for the delete.
post #7 of 16 Old 05-10-2013, 03:00 PM
BIG Laing's Avatar
More power, better miles per gallon, sounds like a diesel, less oil dilution, and smells like a diesel. (You have to get a tuner to delete)
for about 15 minutes after the message pops up cleaning exhaust filter, your instantaneous mile per gallon readout should be like 10 to 12.
post #8 of 16 Old 05-10-2013, 03:06 PM Thread Starter
I haven't noticed that yet. I'll be sure to look closer next time.
Ok. More power and mpg gains are always good.
post #9 of 16 Old 05-11-2013, 06:47 AM
Senderofan's Avatar
I agree with everything except your biggest con. Voiding the warranty is a biggy....but violating state and federal smog laws is much bigger. Looks like the EPA upped the ante in terms of fines...looks like in excess of $30,000 for tampering or removing emissions control parts.
Just saying the troubles with the EPA would probably be bigger and more expensive than the factory warranty issue. Something that needs to be considered in this day and age.
Wayne
2011 F 350 Lariat Ultimate CC, SB 4x4 with 6.7 PowerStroke. Sterling Grey Metallic. Stock rims, tires. Shocks are Bilstein 5160's...what an upgrade over stock!
2013 PW Boss Mustang with aftermarket fully adjustable suspension, Team Dynamic 18"x10" race wheels and 305mm Continental race slicks at all four corners....O/R X pipe, 84.5mm TB, Airaid cai, 47 lb injectors...tuned by AED...Life is fun in this vehicle!
Senderofan is offline
post #10 of 16 Old 05-11-2013, 11:29 AM Thread Starter
I definitely don't need that kind of headache. I've heard that H&S is a great tuner to use even with the emissions parts on.
