track bar bracket for 2.5 level needed - Ford Powerstroke Diesel Forum
post #1 of 15 Old 05-03-2013, 07:29 PM Thread Starter
raftdaddy's Avatar
I just bought a 2012 f350 and have 325/60/20 tires on it now. The dealer threw in a readylift 2.5 kit as the rear sits 2 inches high. it is the kit without the track bar bracket. do I need it? the bracket is 229 by itself.all im adding are 5100's and a dual steering stabilizer not looking to do any other mods whatsoever but just want it to be as safe as possible.
what difference does the camper package make as far as ordering shocks? does it make it sit higher or is it just an added leaf?
2012 f350 lariat,35x12.50x20 on moto metal mo962 in 20x9 with o offset.bil 5100's,readylift 2.5 level
raftdaddy is offline
post #2 of 15 Old 05-04-2013, 08:06 AM
I'm pretty sure the track bar bracket (you don't specify where you are getting this) is for bigger lifts that also include a drop pitman arm. If you drop the track bar and not the pitman you'll have messed up the geometry and get bump steer.
When I leveled my front I used the Icon springs and their adjustable track bar...it needed to be quite a bit longer than stock to center the front end.
2012 F350, 6.7L Diesel, 4x4, SRW, Crew Cab, Short Box, Loaded, Ingot Silver
Detroit Truetrac, Icon leveling springs, steering damper mounts, King reservoir shocks and steering damper, Ultra Predator 22x10 and Nitto Terra 325/50R22 (35"s), H&S Minimaxx & Gearhead, aFe 5" SS w/ muffler, Leer XL, LineX, Titan 50gal, Airlift bags and wireless.
TrickTruck is offline
post #3 of 15 Old 05-04-2013, 02:05 PM
BIG Laing's Avatar
you should definitely get a drop bracket or adjustable track bar. When you lift the front of your truck two and a half inches the entire axle get shifted three quarters of an inch. so when you look straight down your truck from the front one wheel will be poking out an inch and a half farther than the other wheel.
2013 Lariat Eco-Boost F150 Super Crew 4x4 20K Miles. Max-Tow 3.73's, luxury package. Amp Steps, Raceline Raptor Wheels, Bak-Flip, and much more.
BIG Laing is offline
post #4 of 15 Old 05-05-2013, 03:42 AM Thread Starter
raftdaddy's Avatar
I will get one for sure. Thank you
post #5 of 15 Old 05-19-2013, 12:36 PM
Amazon has it under $200.
Sent from AutoGuide.com App
Blue Oval is offline
post #6 of 15 Old 05-19-2013, 12:40 PM
The picture on the site is wrong. I just got one last week. It was $160 or so.
post #7 of 15 Old 05-19-2013, 06:00 PM Thread Starter
raftdaddy's Avatar
We I redress and paid 229 but I'm in Canada so the price of thing in the u.s , you can almost tack on 50 percent or more buy the timer I get it. Thanx for the heads up though
post #8 of 15 Old 05-26-2013, 07:43 PM
BIG Laing's Avatar
Did you get it installed and aligned? where are the pics?
post #9 of 15 Old 05-27-2013, 06:46 AM
2013F250Tank's Avatar
I put a 3" leveling kit on with no track bar drop bracket or pitman arm and now my truck is very wierd steering. Going to buy PMF extended track bar and adjustable 3 link radius arms. Then ill be able to adjust axle back to stock geometry. Find a drop pitman arm from somewhere. Anyone have a sugestion for Drop pitman arm company?
13 F250 Lariat CC SB 3.31 EL axle w/SPE full lock module, Ultimate Interior,
H&S Big Single 64mm NON VGT Turbo Kit, Cast manifolds, NON Cobra downpipe, Mini MAxx w/H&S stock fuel tune
Down Pipe back 304T 4" Diamond Eye, AFE stage II intake, front 4 link,
Road Armor bumpers front/rear. N Fab nerf steps. 20" American Force w/Trxus 33",
Dura flaps, Air Lift rear bags, 34k+ miles, Stage 3 traction block bars.
2012 F250 TOTALED.
Civilian Contractor Airforce 2+ years Asscrackistan.
2013F250Tank is offline
post #10 of 15 Old 05-28-2013, 02:59 PM
Skyd Ram's Avatar
Quoted: 150 Post(s)
Did you do anything the correct the caster? If not I would start with some 1.5 degree caster cams and an adjustable track bar.
Carli Suspension | Pure Performance Suspension | Bilstein Shocks | Fox Shocks
Dynatrac | Flo Pro Exhaust| aFe Power | S&B | BMF | Fuel | Air Dog | Amp Research
Trailready Wheels | Spicer | ARP | REV-X | RIGID Industries | KD Fabworks | Baja Designs
888-886-2480
Skyd Ram is offline
