Defueling problem - Ford Powerstroke Diesel Forum
post #1 of 5 Old 04-19-2013, 02:46 PM Thread Starter
Defueling problem
I put in my mini maxx and installed my 5" exhaust last night.
I took it around town today. It was defueling A LOT. Looked like the pyro was reading way high. Like 2400. I didn't do an egr delete, so were is it getting these egt readings from??
I think I read some where before that if you do exhaust delete and don't do the egr delete with pyro them you have to set up your pyros on the mini maxx a certain way because you'll get erroneous reading and constantly defuel. Does anyone know??
Micheletti is offline
post #2 of 5 Old 04-19-2013, 03:10 PM
SingleCabStroker's Avatar
You need to unplug the egr!!!! pronto. Also set your thing to h&s pyro. It will dimninish your problem and you wont be able to read anything. I just did the egr plates read my thread. It will help. If you dont have to .31 update then its going to defuel your truck quite often. I have mine set conservatively read up on h&s website about what to set your defuels at.
SingleCabStroker is offline
post #3 of 5 Old 04-19-2013, 03:20 PM Thread Starter
I can't figure out how to set it to h&s pyro. I see that I can turn defueling off on pyro 1 & 2
post #4 of 5 Old 04-19-2013, 07:44 PM Thread Starter
Can I just disable the defueling on the pyro??
post #5 of 5 Old 04-19-2013, 09:27 PM
Quoted: 41 Post(s)
Yes^. Disable it until you get a EGT kit to read correct temps.
H&S MinniMaxx
5" Flo-Pro
S&B Intake
Carli 2.5" Backcountry w/Full Leafs
Balla6.7 is offline
