Maximum boost on 2012 6.7 ? - Ford Powerstroke Diesel Forum
post #1 of 11 Old 04-11-2013, 12:42 PM Thread Starter
Hi, just interested what max boost you get when towing. Just over weekend I had first trip with 6.7 to pull my 5th TH and saw maximum 21 PSI boost going over mountains . Is that normal or should go higher ? If so, it is possible to run higher boost with some electronic upgrade ?
milos
milosusa is offline
post #2 of 11 Old 04-11-2013, 01:35 PM
First and foremost, this is not meant to offend the OP in any way. Just a quick bit of information in an attempt to combat a lot of misinformation about diesels.
Boost does NOT equal power. Boost pressure is a sign of restriction, not air flow. Especially in the case of a variable geometry design turbo, boost numbers should not be trusted as a measure of gaining horsepower. With an electrically controlled turbo system, the ECM is attempting to achieve a designated pressure value at all times. If you are outside of a threshold range of desired boost, the ECM will use gain values to open or close the turbo geometry to bring pressure back within range. Suffice it to say that whatever boost your truck is running, is EXACTLY what your ECM is commanding it to run (otherwise you would get a check engine light)
SOOO, to gain more boost, it will close the vanes. Less boost = open vanes. In programming we can command the VGT to provide 60psi of pressure. Does it make more power than when at 23psi of pressure? No way! All we are doing is restricting air flow to the point that cylinder pressures and temperatures are going to cause engine damage.
What do we know? There is a fine line of boost pressure optimization VS engine restriction. Over our many years of working with variable geometry turbos we have gained an extensive knowledge of what does and does not benefit power and longevity. Many still believe that more boost is better, but we are here to express the fact that quite often it is not the case.
As far as your questions about a device to raise boost pressure, yes we have no doubts it is achievable. BUT, we do not believe there would be substantial and reliable results.
H&S Tech is offline
post #3 of 11 Old 04-11-2013, 05:01 PM
Bullitt1289's Avatar
got to love having tech's on here. thanks for the info H&S! OP i believe that 34PSI is the reccomended max the stock turbos can handle so most guys were setting that as the max.
13 F250 FX4 CC Lariat Blue jean metallic
01 Mustang Bullitt #1289
02 F250 XLT 7.3 (sold)
SSgt USAF
Bullitt1289 is offline
post #4 of 11 Old 04-11-2013, 05:22 PM
bbc109758's Avatar
34 is deleted though when stock i could get 22
bbc109758 is offline
post #5 of 11 Old 04-11-2013, 09:36 PM
i wish i has h&s on speed dial lol
]2011 f250 king ranch cc/sb fx4 black and tan allot of inferior parts fell off so i put better ones on . 5inch exhaust axle dump s7b intake . blistien 5100s all the around . 20x12s on 305,55,20s .leveling kit with bags in the rear .5% tint all the way around
lhood6.7 is offline
post #6 of 11 Old 04-15-2013, 07:04 PM
I hope everyone can read this so a lot of arguments can be put to rest, like when everyone says when you hit a certain amount of boost you'll blow a HG. The boost isn't lifting the heads rather the power being made because of the considerable amount of boost thats creating the insane cylinder pressures to lift the heads. I just laugh to myself when everyone always ask, "how much boost you running."
jordan572 is offline
post #7 of 11 Old 04-15-2013, 08:02 PM Thread Starter
I am glad I make you laugh, but I just switch from 2007 Dodge Diesel (for last 15 years I had Dodges ) where stock boost was 22 PSI and just adding Quadzilla controller rise the boost to 32 PSI when towing. That way sorry for maybe stupid question, but not really know to much about new Powerstrokes engines and turbos use on them.
milos
milosusa is offline
post #8 of 11 Old 04-16-2013, 04:07 AM
milos
I should have explained better. I have a 2010 camaro that runs 10-11 lbs and when people ask and I tell them that they say that's nothing my friends Jetta makes 20. That when I laugh. For the most part boost and power in psds and others go hand and hand.
post #9 of 11 Old 03-19-2016, 11:26 PM
Okay partly true what is being explained, I will make this simple most turbos can make 30 psi of boost but the CFM or airflow is not there, also heat is a big variable you can add pressure increasing heat from over working which can cause a loss in power. Super chargers are different I'm using examples please don't start with numbers are wrong thank you. So if a supercharger can move 1000cfm per pound compared to a turbos 400 CFM and heat remember heat if you have 1000 o2 molecules per pound of air at a certain temp the higher the temp goes the smaller the number is colder higher. I'm busy sorry for quick answer
7daysauto1 is offline
post #10 of 11 Old 03-20-2016, 07:39 PM
heleonardman's Avatar
Quoted: 192 Post(s)
Garage
21-22 psi is normal on the stock tuned 11-14 trucks. A lot of guys running upwards of 30#s on the turbo we're seeing failures after a while. The ceramic bearings don't like to spin too fast or get too hot. Too brittle. A nice top end of around 28psi is what I would aim for tuned on stock fueling and stock turbo.
You arent going to get more boost without throwing more fuel at it to efficiently make use of the extra air. You can tune the truck for modest power to upwards of 150hp on the stock fuel system, but it runs out of air and fuel shortly after 500rwhp.
Why do you want to punch the boost up? Not enough power hauling the trailer? What's your rear end gearing?
--HL
2012 F-250 6.7 CCSB XLT
Too many toys for it to list
heleonardman is offline
