6.7 turbo upgrade - Ford Powerstroke Diesel Forum
post #1 of 22 Old 03-15-2013, 07:31 AM Thread Starter
hollywood1983's Avatar
6.7 turbo upgrade
Anyone else see the single turbo upgrade that industrial is going to put out with the borg and warner efr turbo? Very interested with this setup, these companies need to hurry up with the aftermarket stuff for our trucks lol. Long time waiting
2012 f250 fx4 lariat ultimate
2.5 ready lift stage 3
20x9 novakane wheels
S&b cold air intake
35x12.5 R2o
Fox 2.0 shocks
H&s mini maxx
5" flo pro exhaust
Egr block off plates
hollywood1983 is offline
post #2 of 22 Old 03-15-2013, 01:36 PM
First 6.7 PS Destroyer
mysticblu999's Avatar
Quoted: 2 Post(s)
Re: 6.7 turbo upgrade
Seems like everyones is going to hit the market at the same time.
Sent from AutoGuide.com App
2011 F250 6.7 4x4 CC Lariat
6" 4-link BDS
22" Fuel Hostage
37" Toyo MT
H&S BLACK MAXX,
5" MBRP straight pipe
AMP Steps
Truck pics ---->
mysticblu999 is offline
post #3 of 22 Old 03-17-2013, 06:22 AM
DrwKingRanch's Avatar
im pretty excited for this too, I'm more interested in the next compound setup that cuts out the honeywell.
DrwKingRanch is offline
post #4 of 22 Old 03-17-2013, 07:15 AM Thread Starter
Yeah that setup will be nice as well, I just want to get that single setup, but twins sound good a lso.
S&b cold air intake
35x12.5 R2o
Fox 2.0 shocks
H&s mini maxx
5" flo pro exhaust
post #5 of 22 Old 04-08-2013, 05:17 PM
with a 9180 efr I bet you forget all about compounds
cfd_shop is offline
post #6 of 22 Old 04-11-2013, 08:18 AM
Randy_270's Avatar
Quoted: 2 Post(s)
What do you guys mean by "efr" turbo? I just want something I can cruise down the highway at 1500rpm while towing 8-10k and not have the truck lugging. Also better fuel mileage empty, I just did a dpf delete pipe and a spartan tuner and my fuel mileage hasn't changed mostly because I've been driving like a race car instead of a grandpa like I use too lol. And now I'm addicted to the power
2011 F350 Lariat FX4, CCSB, 6.7, 3.55s, 325/65R18 Duratracs, Carli 4.5" Pintop, Flo-Pro, S&B intake, H&S w/ SPE tuning.
2011 Explorer Limited 4WD on 17x7.5s Core Racing Diablo 2s with 245/70R17 Duratracs
Randy_270 is offline
post #7 of 22 Old 04-11-2013, 10:24 AM
it just stands for "Engineered For Racing"
post #8 of 22 Old 04-11-2013, 10:26 AM Thread Starter
Its the style of turbo the efr part. Instead of being a vgt turbo like stock it wont have that.
S&b cold air intake
35x12.5 R2o
Fox 2.0 shocks
H&s mini maxx
5" flo pro exhaust
post #9 of 22 Old 04-11-2013, 08:44 PM
so this turbo will not a vgt it will be a wast gated set up
]2011 f250 king ranch cc/sb fx4 black and tan allot of inferior parts fell off so i put better ones on . 5inch exhaust axle dump s7b intake . blistien 5100s all the around . 20x12s on 305,55,20s .leveling kit with bags in the rear .5% tint all the way around
lhood6.7 is offline
post #10 of 22 Old 04-12-2013, 04:31 PM
The Efr does have a wastegate if you get it in the t3 housing which is .83 a/r or t4 no wastegate on the 9180 which is the largest unit. On the next size down you can get a t4 with wastegate and .91 a/r. This is a 63mm compressor inducer and moves 71 lb/min of air, this one is going to be very popular with diesel enthusiat.
Vgt turbo's have there ups and downs.
Vgt's on the 6.7 have a very tight housing. The turbos easily overspeed and spool to quick which in turn stress load the rods and break them.
Powerstroke owners have been spoiled by the bulletproof International bottoms.
Now the scorpion has a 6 bolt head like a dmax which is very robust, but the rods are like a dmax as well.
This means they need to be tuned like a dmax to keep low end torque to a minimum.
Use mcc or custom tunes to limit boost to 28 psi below 2200 rpm helps
The best solution is to put a better turbo on the truck .
cfd_shop is offline
