delete question - Ford Powerstroke Diesel Forum
post #1 of 13 Old 03-09-2013, 07:00 PM Thread Starter
Quoted: 5 Post(s)
delete question
I've been running my truck with h&s dpf on tuning. I'm planning to delete tomorrow. Will everything be fine to download dpf off tuning or will I need update or anything. My only problem with updating is that I have a mac computer so I can't update it. Also, do I need to download dpf tuning on my truck before I remove the dpf or download once I'm done?
youngstroke is offline
post #2 of 13 Old 03-09-2013, 07:51 PM
Lf83's Avatar
Quoted: 14 Post(s)
delete question
I did pipes first but didn't start truck til I did mini setup. Make sure u turn everything off in truck and don't open doors or do anything that draws power. Heard of a few stories of blanking PCM and guys being stuck til they go to dealer to get flashed. I hooked a charger up to batt to be safe.
leveled 2011 F250
Fox 2.0 Shox
35x12.50x20 Toyo AT II's
20x9 Fuel Dunes
H&S MiniMaxx
5" MBRB 7"Tip
S&B CAI
Lf83 is offline
post #3 of 13 Old 03-09-2013, 09:06 PM
hollywood1983's Avatar
I dont think you need to put it on a charger, but turn eveything off takes about 10 mins to download and load everything. As for a mac computer and updating im not sure. My friend has a mm and could do it on a mac but he had a program that would covert from mac to windows somehow. I would download the tune to the truck first and then delete. You should update from a windows based computer if you can first also.
2012 f250 fx4 lariat ultimate
2.5 ready lift stage 3
20x9 novakane wheels
S&b cold air intake
35x12.5 R2o
Fox 2.0 shocks
H&s mini maxx
5" flo pro exhaust
Egr block off plates
hollywood1983 is offline
post #4 of 13 Old 03-09-2013, 09:25 PM
Yeah it's a Turbo Diesel
mts678's Avatar
Quoted: 18 Post(s)
Feedback Score: 12 reviews
delete question
I have Mac.. You just need to download parallel and it's a virtual machine for windows
Sent from AutoGuide.com App
2017 f250 platinum
Bone stock until warranty expires!
mts678 is offline
post #5 of 13 Old 03-10-2013, 06:02 AM
palmettopowerstroke's Avatar
If you can get ahold of a Windows disk go download virtualbox.org. It's like parallels, but free. You can run Windows on your mac to update your Mini. I just updated the other day with no issues. H&S you need to make a mac updater!
palmettopowerstroke is offline
post #6 of 13 Old 03-10-2013, 06:08 AM
Don't you worry about it
strokinpower's Avatar
Quoted: 277 Post(s)
I can normally update mine with my Mac using the manual updater. I have only had a problem once but the rest of the time it has always worked.
2014 Platipus
AP Intake
Spartan EZLYNK
4" Dual Exhaust
4" BDS with Fox shocks and PMF stage 2 traction blocks
strokinpower is offline
post #7 of 13 Old 03-10-2013, 07:12 AM
mts678's Avatar
Quoted: 18 Post(s)
delete question
Oh wow that's cool I'll have to remember that. Good to know!
2017 f250 platinum
mts678 is offline
post #8 of 13 Old 03-10-2013, 07:29 PM Thread Starter
Quoted: 5 Post(s)
Is 30-35 psi safe? I set de-fuel at 24 but it gets to 32 very quick. Im scared when i tow its going to sustain 28-30 psi? I dont want to ruin my turbo.
post #9 of 13 Old 03-11-2013, 04:44 AM
HorseMover's Avatar
Quoted: 29 Post(s)
So it sounds like you got it deleted. What do you think?
2012 F-350 CC Lariat Dually
HorseMover is offline
post #10 of 13 Old 03-11-2013, 07:39 AM Thread Starter
Quoted: 5 Post(s)
I like it but the boost psi scares me
