Sensor simulators for dpf delete? - Ford Powerstroke Diesel Forum
post #1 of 22 Old 01-30-2013, 07:47 PM Thread Starter
The sensors in the exhaust are simple electronic devices. They are fed some voltage and they have some resistance that varies as whatever they are sensing varies. I think the thermocouples in the pyros actually generate some miniscule voltage that is read by the computer to determine temperature. Does anyone know, then, why it might be hard to engineer a simple electronic circuit that replaces each sensor in the exhaust? I have a very elementary understanding of electronics. I know what resistors, capacitors, relays and diodes do. Beyond that I can't do much. I know how to use a multimeter and how to manipulate Ohm's law and simple stuff like that. It seems possible that with some time and a multi meter, that I could find a way to send the correct signals back to the computer to make it think the sensors are there when they are not.
I already have a delete with a minimaxx, so I don't need to do this. My motivation for looking into this is because I HATE HATE HATE the epa and their twisted version of reality in which deleted trucks are spewing thousands of tons of pollution that are supposedly killing thousands of people.
They can kill the sources of tuners, but they can't kill an idea. If we can work together as a team and this works, then it's also a way to delete without effecting the warranty. No computer modifications would need to be made and it would be totally reversible if we could come up with a way to plug these devices into the oem sensor plugs.
Thoughts?
2011 F350 4X4 CCSB SRW, King Ranch, 3.55, Mini Maxx, 4 inch exhaust, egr gone, Confederate Diesel turbo kit with a S363 and 0.91 twin scroll turbine housing, and stock air filter.
DirtBikePilot is offline
post #2 of 22 Old 01-31-2013, 03:32 AM
I think it's a great idea, I was looking for something like this before I tuned/deleted the truck. I wanted to delete the truck but had no desire for more power/stress on the truck, just wanted it to run clean without all of the emissions BS.
6.7L Stroker is offline
post #3 of 22 Old 01-31-2013, 03:44 AM
BIG Laing's Avatar
Subscribed
2013 Lariat Eco-Boost F150 Super Crew 4x4 20K Miles. Max-Tow 3.73's, luxury package. Amp Steps, Raceline Raptor Wheels, Bak-Flip, and much more.
BIG Laing is offline
post #4 of 22 Old 01-31-2013, 06:44 AM
jrshelton13's Avatar
Thoughts?
Its because of people like yourself that we have great ideas and why I don't think this tuner ban will last too long. This is a great idea and I will be following this thread for a while!
I'm with you on the EPA. It sure doesn't make sense to have an organization that doesn't have anyone to answer to or regulate them. I hope people smarter that me can get together and get this one figured out.
jrshelton13 is offline
post #5 of 22 Old 01-31-2013, 07:26 AM
Tj Krawler's Avatar
There is some hope to this. It's been done on the earlier 6.7 Dodge's. With resistors for ~$5. I assume there is also back pressure sensors in the DPF you will have to "trick" as well. But as long as they see the right voltage/resistance. I think it would throw a code if the truck tried to regen, but if it doesn't sense enough back pressure (regen's are activated by back pressure, right?) it shouldn't try to regen at all.
I get the idea that Ford already planned for this though.
Alan
2000 F-350 CC LB DRW 4x4 XLT Auto
- Intake
- Exhust
- ScanGauge
Tj Krawler is offline
post #6 of 22 Old 01-31-2013, 05:37 PM
BIG Laing's Avatar
I believe regens are triggered by soot load. There is a backpressure sensor though, maybe its a POKE-YOKE.
post #7 of 22 Old 01-31-2013, 05:44 PM
Don't you worry about it
strokinpower's Avatar
Quoted: 277 Post(s)
I don't know about the 6.7's but on the 6.4's even if you trick the sensors the truck will go into regen after a certain mileage.
2014 Platipus
AP Intake
Spartan EZLYNK
4" Dual Exhaust
4" BDS with Fox shocks and PMF stage 2 traction blocks
strokinpower is offline
post #8 of 22 Old 01-31-2013, 05:50 PM
BIG Laing's Avatar
Then we could have even more flames coming out of our exhausts then the 6.4's with the DPF problems! That could cause some issues...
If you have never seen the "flamethrower" 6.4's, hop on youtube and check it out.
post #9 of 22 Old 01-31-2013, 06:27 PM
Bryce18's Avatar
Quoted: 19 Post(s)
Re: Sensor simulators for dpf delete?
Subscribed
Sent from my DROID RAZR using AutoGuide.Com Free App
'11 F250, 6.7 PSD, 3.55 gears, FX4 CC,SB,KR,5% tint, Hankooks w/ moto metal 959's, B&W hitch
Mods
S&B CAI
H&S MINI
5" mbrp strait pipe
H&S EGR block offs
VIAIR OBA
U.P.train horns
Bryce
Bryce18 is offline
post #10 of 22 Old 01-31-2013, 06:43 PM
Keel056's Avatar
Quoted: 4 Post(s)
Thats similar to what we did with mustangs and cameros. Had to use O2 simulators when we took the cats of the exhaust.
20'12 F350 CCLB Lariat
Wheels 22" gear
Tires 37x13.50 falken
3.55 w/e-locker
2'' front level
ranchhand bumpers
Navigation
EZ Down tailgate assist
5th wheel prep
Keel056 is offline
