mini maxx and torq 2.1 - Ford Powerstroke Diesel Forum
post #1 of 11 Old 01-23-2013, 12:07 AM Thread Starter
bronze 6.7's Avatar
Anyone running a mini maxx and torq 2.1? If so what level do you run the torq 2.1 on? I know each truck is different just wanted to see what you guys are doing. I ran the torq 2.1 on my truck with a xrt pro and was able to run it on level 9 with the xrt set on hot also. I swapped to a mini maxx and so far I'm only able to run it on level 5. Anyone run into this?
bronze 6.7 is offline
post #2 of 11 Old 01-23-2013, 04:52 AM
You guys stacking H&S with Torq's are just begging to throw a rod, or 8, aren't you!!?? LOL... I run my Black Maxx DPF off on NO POWER and I'm still scared for my truck's engine every day I drive it.
6.7L Stroker is offline
post #3 of 11 Old 01-23-2013, 07:36 AM
Dman115's Avatar
What happens when you run it hottet? I have a mini maxx and am looking at getting the torque 2.2 but want some input?
Dman115 is offline
post #4 of 11 Old 01-23-2013, 10:19 AM Thread Starter
bronze 6.7's Avatar
When i run the mini maxx on hot with the Torq on level five at 100% it runs out of fuel. When i had the xrt on it with the torq on level nine at 100% it would run like a raped ape and wouldn't run out of fuel. The fuel mileage with the torq helped allot. Did the best with the torq set on five and the xrt on hot
post #5 of 11 Old 01-23-2013, 11:00 AM
Dman115's Avatar
By 100% do you mean full throttle?
Dman115 is offline
post #6 of 11 Old 01-23-2013, 11:11 AM
I stacked mine for about 2 minutes, long enough for the computer to say there was a fuel pressure problem, took the Torq off and the truck ran fine.
cmb396 is offline
post #7 of 11 Old 01-23-2013, 07:44 PM Thread Starter
bronze 6.7's Avatar
On my torq module it has nine power levels and each level you can adjust power from 0-100%.
2011 CC/SB
mini maxx
mbrp duals
torq 2.1
afe intake
20x9 RBP 94R
35x12.50 nitto trails
post #8 of 11 Old 01-23-2013, 07:47 PM
Dman115's Avatar
Ahh i see. I think im going to order the 2.2 from innovative shortly. Squeez a little more power out. On a side note how do you like your trail grapplers?
Dman115 is offline
post #9 of 11 Old 01-23-2013, 08:49 PM Thread Starter
bronze 6.7's Avatar
I really like my trail grapplers. I have 30k on them and have around 40% left. Not bad for a mud tire. The road noise is very low. A real good quiet tire. The only problem i have with them is that i farm and run gravel roads all the time and they are starting to chunk out on the outside lugs where a small grove is cut. That's my only problem i have with them. They don't pick up rocks like other tires do. I would definitely recommend them.
2011 CC/SB
mini maxx
mbrp duals
torq 2.1
afe intake
20x9 RBP 94R
post #10 of 11 Old 01-23-2013, 09:18 PM
Dman115's Avatar
I have pro comp xtreme a/ts now but when there done im getting a set
Dman115 is offline
