About to delete/tune... Got a question - Ford Powerstroke Diesel Forum
post #1 of 8 Old 12-03-2012, 02:44 PM Thread Starter
Quoted: 9 Post(s)
I have a 12' 6.7 with almost 10k problem free miles. I have ordered an H&S MM tuner, 4" Flo-Pro exhaust w/o muffler, and S&B intake. I couldn't decide on exhaust with or without muffler. Figured I would try straight pipe and if i don't like it then I will add muffler. I did a lot of researching on this forum before deciding on this combo.
My question is... I have seen a lot of people talk about EGR delete kits. I was under the impression that my H&S tuner will bypass the EGR without having to completely delete/unbolt the EGR. Is that correct? I don't want to run EGR but would like to keep it bolted in case I need to return to stock.
Ford#2oil is offline
post #2 of 8 Old 12-03-2012, 06:20 PM
The tuner will bypass the EGR but you need to delete it. Its not that bad to put the block off kit on. Its fairly easy to return to stock if you ever need to.
MotoGuy114 is offline
post #3 of 8 Old 12-03-2012, 06:52 PM Thread Starter
Quoted: 9 Post(s)
might be a dumb question but what is the point of deleting the EGR if the tuner bypasses it?
post #4 of 8 Old 12-03-2012, 07:12 PM
Quoted: 2 Post(s)
High boost can still blow through the valve.
2012 F250 CCSB 6.7 (3.73 gears) H&S Minimaxx (My own tuning), H&S 64mm turbo kit, H&S Dual Fueler, H&S Low Pressure Fuel System, H&S CCV delete, No Limit s2 Intake, PMF 3-link, PMF traction bars, Fox 2.0s, Icon 2.5" coils, Platinum 20s w/ 295/65 toyo at2s, Airlift bags and wireless controller, TFI 50gal, rollX, AMPboards,
jcain is offline
post #5 of 8 Old 12-03-2012, 07:19 PM Thread Starter
Quoted: 9 Post(s)
makes sense. how much does a block off kit cost?
post #6 of 8 Old 12-03-2012, 07:44 PM
I believe the kit is about $150
Firemedzo1078 is offline
post #7 of 8 Old 12-03-2012, 07:45 PM
Quoted: 2 Post(s)
Around 100
jcain is offline
post #8 of 8 Old 12-04-2012, 09:48 AM
Bryce18's Avatar
Quoted: 19 Post(s)
If you just get the h&s block off plates I believe they are like $35.00 the 2 plates replace the short egr pipe going from down pipe to egr.
The plate that bolts on to the downpipe has a spot to bolt on an exhaust sensor that you take out of the stock exhaust which will read your exhaust temp.
The other plate bolts onto the top of egr.
Sent from my DROID RAZR using AutoGuide.Com Free App
'11 F250, 6.7 PSD, 3.55 gears, FX4 CC,SB,KR,5% tint, Hankooks w/ moto metal 959's, B&W hitch
Mods
S&B CAI
H&S MINI
5" mbrp strait pipe
H&S EGR block offs
VIAIR OBA
U.P.train horns
Bryce
Bryce18 is offline
