Sinister Diesel EGR Delete installed - Ford Powerstroke Diesel Forum
 1Likes
post #1 of 82 Old 12-01-2012, 02:20 PM Thread Starter
JimNVA's Avatar
Hey gang, I was debating to or not to install the EGR Delete today. Concerns were: draining the coolant, the estimated time to complete (since I was starting around noon; I saw a few posts where folks said it took 6 hours and some that said they had to finish up the next day) and of course, jacking something up in the process.
According to the instructions, it says drain the coolant, so I did that first. Ok, back up, I went to the auto parts store and got 5 gals first. Then I drained the coolant. Well, I got 5 gals because the instructions said expect to drain 3 gals from one side and 2 from the other. OK, for some odd reason only 2.5 gals came out. So that was done, then I just followed the rest of the instructions. The Sinister Diesel instructions were ok, but the pictures were horrible, or it was a copy of a copy of a copy, too dark. I guess I figured it out.
My tips/must haves:
socket swivel (to get to most of the bolts)
10" ratchet extension (to get to most of the bolts)
If you have an S&B intake, the install goes quicker
PULL THE GRILL OFF!!!! Not in the instructions, or I didn't see it, but it helped getting to that lower coolant hose.
The EGR Cooler was a beeoch to get out of there, you have to twist/turn it just right to get the back end out...not sure how I did it, but it finally came out.
Getting all that crap off took about 2 hours, actually putting the kit on took about 30 minutes including putting the intake back on.
Total time was about 2.5 hours, not sure how I did it in that time, but I did do a bunch of reading and read both the H&S delete and the Sinister delete instructions a few times before I even got the kit.
Now when the EGT kit arrives it should only take like 5 minutes to install.
Oh yeah, it happened.....
Tuxedo Black 2011 F250 Lariat FX4
Originally Posted by stan60 View Post
Probably one of those deals that you ask 10 guys and get 10 different answers. I'm keeping what I have. I like the look, I like the sound. I don't think you would ever notice the difference on the street. Maybe on the dyno, but I don't ride there.
JimNVA is offline
post #2 of 82 Old 12-01-2012, 03:27 PM
"Stroker 8"'s Avatar
Quoted: 4 Post(s)
Looks good you can help me do mine when the time comes. Post up your EGT install once you've installed it. Thanks for sharing
Larry
2015 F-350 CCLB DRW, Lariat Ultimate,
2nd Gen. 6.7L "Scorpion" Turbo Diesel,
440HP/860TQ, Torque Shift 6-speed,
Tuxedo Black W/Charcoal Black Int.,
14,000 LB GVWR,
3:73 Gears W/Limited Slip,
17" Polished Forge Alum. Wheels,
BFG All-Terrain Tires,
Factory 5th Wheel/Gooseneck Prep Pkg.,
Spray In Bed-Liner,
Supplemental Cab Heater,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
Engine Block Heater,
9025 Lbs. on the CAT Scales.
"Mack Daddy Scorpion!"
"Stroker 8" is offline
post #3 of 82 Old 12-01-2012, 10:11 PM
Are you out of warranty or just don't care.
Seems like it would be a ***** to put back to stock if something non engine related happened but I did not want them to see it and void **** not related.
I know doing the delete lessens chances of **** going wrong though.
*SOLD*2008 F250 6.4: H&S Mini w/ Bully dog mount, Flo-Pro DPF/CAT delete, AFE stage 2, Viper 5901 Remote start.
2012 F250 6.7: S&B CAI, H&S Mini Maxx, 5" MBRP straight exhaust, Firestone airbags.
Grunnsetning is offline
post #4 of 82 Old 12-02-2012, 05:17 AM
Nissankidd's Avatar
Looks clean. That might be my next mod.
2015 F-250 platinum
Nissankidd is offline
post #5 of 82 Old 12-02-2012, 02:35 PM
brandonlee0034's Avatar
How are you guys going about draining the coolant? Don't you need a vacuum pump because of the coolant valves?
2011 F250 6.7
Stock...?
brandonlee0034 is offline
post #6 of 82 Old 12-02-2012, 02:43 PM Thread Starter
JimNVA's Avatar
Pretty much don't care about warranty work. There are a hand full of dealers around plus I have a pro mechanic that owns a Powerstroke as a daily driver that can bail me out.
I just drained straight out of the two plugs on each side. I used the tubes that came with my reverse bleeder kit, pretty much no mess.
JimNVA is offline
post #7 of 82 Old 12-03-2012, 09:23 AM
barobbin's Avatar
Quoted: 3 Post(s)
doesnt the sinister delete come with a spot for the egt sensor and you just use the stock one out of the exhaust? i bought a kit from them and thats what they told me at least. i will be installing mine after christmas
barobbin is offline
post #8 of 82 Old 12-03-2012, 09:28 AM Thread Starter
JimNVA's Avatar
There's a pre-tapped hole with hex screw in it in the manifold blockoff plate, but I think it's a smaller diameter for an aftermarket sensor. I didn't even check to see if the sensor fit because I ordered the H&S EGT kit.
JimNVA is offline
post #9 of 82 Old 12-03-2012, 09:51 AM
First 6.7 PS Destroyer
mysticblu999's Avatar
Quoted: 2 Post(s)
Looks good. I've been wanting that but think I will want for a new turbo before i do it.
Sent from my SAMSUNG-SGH-I717 using AutoGuide.com App
2011 F250 6.7 4x4 CC Lariat
6" 4-link BDS
22" Fuel Hostage
37" Toyo MT
H&S BLACK MAXX,
5" MBRP straight pipe
AMP Steps
Truck pics ---->
mysticblu999 is offline
post #10 of 82 Old 12-03-2012, 11:51 AM
barobbin's Avatar
Quoted: 3 Post(s)
they told me that the stock one will fit. could you check and see if that is true? because if not i am going to have to buy a egt kit.
thanks,
Brad
barobbin is offline
