HELP ICON 4.5 INCH LIFT KIT - Ford Powerstroke Diesel Forum
post #1 of 17 Old 11-18-2012, 03:17 PM Thread Starter
Question HELP ICON 4.5 INCH LIFT KIT
Hello everyone! I am new to the forum and currently have a 6.7. I was looking for any input on the icon 4.5 inch lift. Is it REALLY worth the money? How does it hold up? Should i just look at the pro-comp 6 inch stage 2 kit for 800 less? In the end i would like to run 35 inch tires.
Thanks in advance, any input and/or pictures of your trucks can help me tons!!
lrsfordf350 is offline
post #2 of 17 Old 11-18-2012, 03:21 PM
Don't you worry about it
strokinpower's Avatar
Quoted: 278 Post(s)
I wish I wouldn't have tried to save a little money and gone ahead and gone with the icon.... And if you want to run 35's they look perfect with 4.5 lifts.
2014 Platipus
AP Intake
Spartan EZLYNK
4" Dual Exhaust
4" BDS with Fox shocks and PMF stage 2 traction blocks
strokinpower is offline
post #3 of 17 Old 11-18-2012, 04:19 PM
BIG Laing's Avatar
I have researched for months, and I am set on icon. You can run 35" with a stock truck, so no problems there. 35's do look awesome.
Level 1,2,3,4 or 5?
2013 Lariat Eco-Boost F150 Super Crew 4x4 20K Miles. Max-Tow 3.73's, luxury package. Amp Steps, Raceline Raptor Wheels, Bak-Flip, and much more.
BIG Laing is offline
post #4 of 17 Old 11-18-2012, 04:21 PM
I have a stage 2 4.5 the quality is much better but ride is about the same as stock. I never owned a different lift but installed a procomp once and there is a significant difference in fit and finish. If you plan on using your truck offroad you are probably better off going Icon.
2012 F250 King Ranch Black Deleted
2013 BOSS 302
2007 GT500
2004 Cobra
2001 Lightning
PUMPED 101 is offline
post #5 of 17 Old 11-18-2012, 04:28 PM
Big_Smokey's Avatar
Quoted: 9 Post(s)
mine is on a 6.4. I bought it used off here. its just the stage I kit with bilsteins and Its way better then my stock ride. Super easy to install. Only difference between the 08-10 kits and yours i think is the radius arm brackets. Also if your rear axle is a two piece you will want to look into carrier bearing shims or take it to a driveline shop to get you hooked up. ive got some pics of my truck with 35s and this lift. I think it looks really good. you can get away with a leveling kit if you wanted also and some nice shocks.
Big_Smokey is offline
post #6 of 17 Old 11-18-2012, 05:12 PM Thread Starter
Big Laing,
I agree with you on the 35s looking good! I was leaning towards the Stage 3 kit.
post #7 of 17 Old 11-18-2012, 05:14 PM Thread Starter
Thanks for the Input/ pics guys! I really appreciate your ideas as i have been struggling with this choice for a while now. Icon only seems to get better as i learn more about them.
post #8 of 17 Old 11-18-2012, 05:41 PM
Skyd Ram's Avatar
Quoted: 151 Post(s)
Originally Posted by lrsfordf350 View Post
Big Laing,
You owe it to yourself to look at the Carli and Pure Performance 4.5" lifts if that is your budget.
Carli Suspension | Pure Performance Suspension | Bilstein Shocks | Fox Shocks
Dynatrac | Flo Pro Exhaust| aFe Power | S&B | BMF | Fuel | Air Dog | Amp Research
Trailready Wheels | Spicer | ARP | REV-X | RIGID Industries | KD Fabworks | Baja Designs
888-886-2480
Skyd Ram is offline
post #9 of 17 Old 11-18-2012, 07:18 PM
layson's Avatar
Quoted: 84 Post(s)
Go with the Icon you will be happy.
Whenever I have lift kit questions I give these guys a call.
2001 - 14" OUO 525 - 38x15.5x20 Toyo & 20x12 Weld Cheyenne's. Hybrids, 38R, BTS, Spearco, Terminators..
Quote of the Day:
Originally Posted by Mannysouza View Post
You will get some axle wrap with a heavy trailer, I can feel it when towing my gooseneck with some heavy equipment. My Deavers will wrap enough to make the tires rub the front of the rear fender well if I give it too much throttle on aceleration.
layson is offline
post #10 of 17 Old 11-18-2012, 07:29 PM
BIG Laing's Avatar
I have looked at carli quite a bit. I don't want to replace my rear leafs. If $ wasn't an issue I would run icon 4.5 stage 5, ALA, and OUO traction blocks.
