Defuel - Ford Powerstroke Diesel Forum
post #1 of 14 Old 11-02-2012, 04:03 AM Thread Starter
Defuel
I just a mini maxx and deletes to my truck and was wondering what everyone was seeing for egts and what you have your defuel set at
Sent from my iPhone using Autoguide.com App
redrider8293 is offline
post #2 of 14 Old 11-04-2012, 06:43 AM
I have left mine at the default that was set on the unit and hasn't been an issue but I don't drive it hard on a regular basis. I did notice that when I was doing the trans relearn process, I hit the defuel limits during the 0-80 at wot run.
-John
2012 F350 6.7L CC/SB, Carli 4.5" Pintop, 315/70/18 Toyo MT, Method Standard Wheels, Icon Dual Stabilizer, Mini-Max, S&B intake,Line-x, Access Bed Cover, Titan 50g, AMP power steps
ktmrider is offline
post #3 of 14 Old 11-04-2012, 11:16 AM
Bryce18's Avatar
Quoted: 19 Post(s)
I think the most important defuels are egts (Pyro 1) and turbo boost.
I would set defuel on Pyro 1 to 1400 or 1450. Keep in mind its a good idea not to keep it at the temp for ling periods of time.
I also set my boost to 34psi. I did this only to possibly prevent my turbo to over work itself. Stock these turbos only see obout 20-22 psi. Tuned and deleted I see between 30-36psi
Sent from my DROID RAZR using AutoGuide.Com Free App
'11 F250, 6.7 PSD, 3.55 gears, FX4 CC,SB,KR,5% tint, Hankooks w/ moto metal 959's, B&W hitch
Mods
S&B CAI
H&S MINI
5" mbrp strait pipe
H&S EGR block offs
VIAIR OBA
U.P.train horns
Bryce
Bryce18 is offline
post #4 of 14 Old 11-05-2012, 11:53 AM
Great advice here, we set defuel at 1450 for pyro and only 32 for boost. These chargers are expensive, and anything above 32 is gray area... For what its worth.
H&S Support is offline
post #5 of 14 Old 11-05-2012, 05:33 PM
Bryce18's Avatar
Quoted: 19 Post(s)
That's why I'm ready for the aftermarket single turbo that you guys have been testing out!
Mods
S&B CAI
H&S MINI
5" mbrp strait pipe
H&S EGR block offs
VIAIR OBA
U.P.train horns
Bryce
Bryce18 is offline
post #6 of 14 Old 09-29-2013, 03:56 AM
Scorpion 2012's Avatar
[QUOTE=redrider8293;3322029]I just a mini maxx and deletes to my truck and was wondering what everyone was seeing for egts and what you have your defuel set at
Search old threads here, but I thought that when someone runs deletes, they wouldn't have to defuel or am I confusing that with regen.? Help a newbee out, thanks in advance.
Scorpion 2012 is offline
post #7 of 14 Old 09-29-2013, 03:58 AM
If he's running a '13-14 model truck, there is no need to limit the boost, all of the tuning available for the new models runs much lower boost. Highest I have seen on my '13 is 26psi.
'13 F250 CCSB Black/Black: Carli Starter & Stabilizer, Minimaxx, S&B intake, 5" FloPro, egr blocker, BMF Rehabs, Toyo AT IIs, Titan 50gl Tank, Amp steps, Blacked Out Tails/3rd/Markers, Full Custom Sound
highdrum is offline
post #8 of 14 Old 09-29-2013, 04:35 AM
thanks highdrum
post #9 of 14 Old 09-30-2013, 07:13 AM
WoodBoy's Avatar
I wouldn't set a defuel on the pyro, I would set my defuels on my coolant and tranny temps though until they reach 175-180 on the coolant and 120 or so on the tranny
2010 CC/SB FX4 Lariat.. Tuned By Eric@IDP and Matt@Gearhead
Thinking about getting rid of the stock 6.7 turbo?
Check this out... and research before buying
WoodBoy is offline
post #10 of 14 Old 11-24-2013, 12:50 PM
99PSD-White's Avatar
Thats good to know. Thats all I see on my 2013 as well. I see people saying they get 30-36 and I was thinking I had a problem.
2013 F250 Lariat 4x4 Loaded. H&S mini maxx, 5" exhaust, S&B intake, and EGR delete, AMP steps, tonneau cover
2011 F150 Ecoboost FX4 Screw. All stock except for a livernois Tuner. SOLD!
Early 99 CCLB Pro comp 6.5" lift w 18" hulk wheels wrapped in 37" KM2s, Amp steps, Straight pipe, AIS intake, Dp Tuner, isspro gauges (boost,trans,pyro), 05 front clip, traction bars, 6.0L trans cooler, built trans.SOLD!!
99PSD-White is offline
