Edge CTS/XRT pro or mini max? - Ford Powerstroke Diesel Forum
post #1 of 17 Old 10-30-2012, 06:39 AM Thread Starter
Idiesel's Avatar
Okay guys, I'm wanting to add more gauges so I can monitor more parameters like dpf regen status, urea level, amps and so on. I have looked at the CTS and the mini max and both will monitor what I want but for in the future I will want to do a dpf/urea/egr delete when I hit 5-10k miles. So would it be better to run the CTS with the XRT or just go straight for the mini max? I don't plan on running a really hot tune probably just stock tuning most the time. Thanks
Idiesel is offline
post #2 of 17 Old 10-30-2012, 01:52 PM
I would just go with the mini max in your case instead of getting both the CTS and the XRT.
schnet1 is offline
post #3 of 17 Old 10-30-2012, 02:55 PM
DSTRBD's Avatar
Agreed. The Mini Maxx is definitely the way to go.
ICON Vehicle Dynamics | S&B Intakes | MBRP Exhaust | American Force Wheels | Diamond Eye | AFE Intakes | Carli Suspension | Industrial Injection | Garrett Turbos | FASS | Method Wheels | Bilstein Shocks | Airdog | KMC Wheels | Spartan | RSouth Bend Clutch | SCT | Edge Products | ATS Diesel | Bullydog | BMF Wheels | AMP Research | & much more....
DSTRBD is offline
post #4 of 17 Old 10-30-2012, 03:01 PM Thread Starter
Idiesel's Avatar
It just sounded better getting the insight now bc of the price just for monitoring parameters. But in the long run y'all are right, it would save me the hassle and only have one device. Thanks guys!!
Idiesel is offline
post #5 of 17 Old 10-30-2012, 03:01 PM
I have the CTS:
I really like it and I always run it on Level 1. It's basically stock, doesn't add any power but runs smoother, and honestly it does, pedal response is incredible, as well as fuel economy. I never ran a XRT , trust me you will be surprised on the performance you get on level one:
Level 0: Stock
Peak to Peak Gains:
Level 3 – 80 HP 180 tq
Level 2 – 65 HP 150 tq
Level 1 – No added power. Optimizes stock tuning with custom options feature to run smoother
Hope this helps and keep us posted on your choice and reviews on you decision, thanks
Easy come ! Easy Go
thisgr8ride is offline
post #6 of 17 Old 10-30-2012, 03:19 PM Thread Starter
Idiesel's Avatar
Originally Posted by thisgr8ride View Post
I have the CTS:
Level 0: Stock
Peak to Peak Gains:
Level 3 80 HP 180 tq
Level 2 65 HP 150 tq
Level 1 No added power. Optimizes stock tuning with custom options feature to run smoother
That's a clean looking setup! I'm eventually going to delete everything so that's the only downfall of buying the edge, But we will see. I wish I knew somebody that had a tuned 6.7 locally that way I could play around and get the feel for one.
Idiesel is offline
post #7 of 17 Old 10-30-2012, 04:57 PM
travisH3's Avatar
Quoted: 2 Post(s)
Feedback Score: 13 reviews
If you dont want the tune on the fly option of the mini maxx, the xrt and cts insight would be sweet. The cts i believe can monitors more parameters and also more parameters at once where with the mini maxx your limited to 4. Plus the cts also has options for back up camera if that interests you. or you could wait for h&s new tuner to come out that is replacing the discontinued black maxx. Im thinking it will be more up to par with spartans monitoring. hopefully it also has the back up camera option. If it does i will be replacing my mini maxx with it! I had a cts with back up cam on my 6.0 and man it sure does making hooking up to the equipment and boats a heck of a lot easier by your self.
T-rav
2010 F350 6.4-
s467 MPD single kit, H&S Jesse Byall tuning, No limit IC piping and intake,mishimoto intercooler, MPD billet CCV/oil filler, FASS with sump, SOTA A.W.O.L. polished wheels, toyo rt tires, RED Newton traction bars, oem projector retrofit and a bunch of LED lights LOL
Holderdown Performance #teamHDP
OUR FLEET: 2015 f450, 2014 Platinum F350, 2012 F450 6.7, 2010 F350 6.4, 2005 F350 6.0, 04 F450 6.0
travisH3 is offline
post #8 of 17 Old 10-30-2012, 08:30 PM
6.0L Stroker's Avatar
I have a mini maxx and love it. But if the new black maxx resembles the touch screen spartan or the new sct I may upgrade to that for more features
2011 F350 CC/SB Bronze and Gold KR tinted windows, spray in bedliner. MBRP 5in filter back with 6in tip and Mini Max. S&B Dry Intake, TGC Dual Stabalizer.
Sold 2004 Ford F-350, cc/lb Lariat, Procomp 6.5 lift with 37/13.5/17 Toyo Mts, Id tuned Ficm, Bully Dog Triple Dog, MBRP all the way back,
6.0L Stroker is offline
post #9 of 17 Old 10-30-2012, 08:40 PM
Yeah it's a Turbo Diesel
mts678's Avatar
Quoted: 7 Post(s)
Feedback Score: 12 reviews
I tune with the h&s and run the hd300. But I watch everything with my edge cts because its wayyyy better for monitoring- you can watch 8 things vs 4 on the h&s...easy decision for me
Marshall
2002 F250 7.3L CCSB 4WD
Tinted | Focal speakers & 12" Kicker | CTS Insight | CNC fuel line kit | PIS 200/80's | KC38R | Nathan P3 train horns & Onboard Air
mts678 is offline
post #10 of 17 Old 10-31-2012, 07:20 AM
Send a message via AIM to Mr Powell
Newbie question to some effect, but some of the parameters I see you can watch are completely useless even for towing. Am I not seeing something here? I didn't use any on my 04 Duramax (back in 04-06 ran Power Pup @ 155hp and Edge at 125hp on stock trans for 2 years). My 12v experience is from my buddies compound setup and it's boost, egt and backpressure; truck makes ~900rwhp/1650rwtq. Is it that much of a difference now on the newer diesels?
I've had nothing but gas motor trucks since 06 until this year so not sure whats changed that would need to be watched over. I did a Edge Evo/HT at 200 miles and at 5k I went with a DPF delete and a H&S XRT Pro and I LOVE IT (1600 miles into so far).
Daily: 2012 Ford F-250
Mods: H&S MiniMaxx (SPE Hot X Tune) ... AFE DPF Delete ... Magnaflow Muffler Delete ... AFE Drop In Filter ... Carli 2.5" PinTop 2.5 ... BMF 20x10 Novakane
Non-Daily: 2002 Porsche Turbo
Mods: Boost Logic Built ... 1040rwhp on E85 ... 1150rwhp on C85 ... Freshened Up Motor and Syvecs ECU coming soon ... BIG POWER!
Mr Powell is offline
