H&S let me keep my dpf,urea and egr? - Ford Powerstroke Diesel Forum
post #1 of 13 Old 07-14-2012, 11:45 PM Thread Starter
hey all iam thinking about buying a used 6.7 within the next year or so , but l live in ontairo canada and we have emissions testing .i know the 6.7 can be reliable with out all the emission crap, but will the h&s turner let me keep everything in place dpf,urea and the egr but shut them off and turn everything on again come emission test time.thanks
classicxl is offline
post #2 of 13 Old 07-15-2012, 02:54 AM
"Stroker 8"'s Avatar
Quoted: 4 Post(s)
Great question! I'm stock so I will let somebody else answer this. BTW,
Larry
2015 F-350 CCLB DRW, Lariat Ultimate,
2nd Gen. 6.7L "Scorpion" Turbo Diesel,
440HP/860TQ, Torque Shift 6-speed,
Tuxedo Black W/Charcoal Black Int.,
14,000 LB GVWR,
3:73 Gears W/Limited Slip,
17" Polished Forge Alum. Wheels,
BFG All-Terrain Tires,
Factory 5th Wheel/Gooseneck Prep Pkg.,
Spray In Bed-Liner,
Supplemental Cab Heater,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
Engine Block Heater,
9025 Lbs. on the CAT Scales.
"Mack Daddy Scorpion!"
"Stroker 8" is offline
post #3 of 13 Old 07-15-2012, 05:47 AM
srjd's Avatar
Quoted: 2 Post(s)
I'm planing on moving back to Ontario in a year I hope I don't have a hard time since my dpf and egr fell off. Hopfully living in a small town knowing someone will make it easier
01/07 Job 1 F350 H&S Tuned. ARP Studs, AFE 4'' straight pipe, EGR delete with elbow, AFE stage 2 CAI, 6'' lift on 37s, 20x12 Fuel Nuts two piece, Sinister coolant filter, CCV Mod, Projector headlights HID kit
srjd is offline
post #4 of 13 Old 07-15-2012, 05:48 AM
srjd's Avatar
Quoted: 2 Post(s)
To answer your question I don't think u can just shut the dpf off with leaving it on the truck. The egr on the other hand you can. How often is the testing?
srjd is offline
post #5 of 13 Old 07-15-2012, 02:02 PM Thread Starter
hate to tell u but once your truck is 3 years old you need a e test every 2 years, theres a visual test to make sure that your dpf,egr and urea are in place or u won't pass .i have read of guys passing with a visual and dpf.egr missing but some shops do both ob2 and visual .
sounds like from the reading ive done i will have to put my dpf back on every two years come e test time, or see if i can get like diesel doctors to do my e test i hope they change the e test from2-5 years like they want to.
how do u disconnect the urea through is it a few lines then turn it off with a turner.
post #6 of 13 Old 07-16-2012, 05:52 PM
Why not rig up some external housing around your exhaust that looks like a DPF so it looks factory, but run the 5" pipe right through it for aesthetics?
Strokin'Hokie is offline
post #7 of 13 Old 07-16-2012, 06:11 PM
ABP
If you left the DPF on the truck but shut it off in the computer I would think it would eventually clog. The DPF would still catch all the soot and with regen shut off it would never clean it out.
2012 F250 Lariat CC/SB 4X4-traded
2013 Ram Mega Cab 4x4 Long Horn-traded
2015 F250 King Ranch CC/SB 4x4-happy to be back
ABP is offline
post #8 of 13 Old 07-17-2012, 03:34 AM Thread Starter
the only problem i think i may run into is i think most shops will put the truck on a computer to check the emission. i think i might just reinsteal the dpf every 2 years for emission test, but how do u unhook the urea tank.
post #9 of 13 Old 07-17-2012, 03:45 AM
Don't you worry about it
strokinpower's Avatar
Quoted: 277 Post(s)
You can not turn the DPF off and leave it in place because it will just clog up.
2014 Platipus
AP Intake
Spartan EZLYNK
4" Dual Exhaust
4" BDS with Fox shocks and PMF stage 2 traction blocks
strokinpower is offline
post #10 of 13 Old 07-17-2012, 04:06 AM
svtdiesel's Avatar
It may be different, but on the 08-10 you can hollow DPF, CAT, and Delete EGR coolers, and still pass the plug in emissions test. On the 310 at that.
svtdiesel is offline
