CTS Insight? - Ford Powerstroke Diesel Forum
post #1 of 6 Old 07-12-2012, 06:48 PM Thread Starter
CTS Insight?
For you fine people that have an Insight on your 6.7, what are you monitoring? Will it display what gear the transmission is in? Also what EGT point would be the best to monitor?
Thanks,
Randall
Boss 302 is offline
post #2 of 6 Old 07-12-2012, 11:35 PM
2006F350's Avatar
Ambient Air Temp, Accel Pedal Position, Barometric Pressure, Battery Voltage, Corrected Speed, Dist. Between Regens, Dist. Since DTC Clear, Dist. Since Regen, DPF Pressure, DPF Soot Mass, DTC Count, EGT Post DPF, EGT Pre DPF, EGT Post Turbo, EGT Post SCR/Pre DPF, Engine Coolant Temp, Engine Load, Engine Oil Temp, Engine RPM, Engine Run Time, Fuel Level, Fuel Rate, Gear with Reverse, Gear with TCL, Intake Air Temp, Manifold Abs Pressure, Mileage Coach, MPG Instant, MPG Average, Nox PPM, Regeneration Status, Reductant (Urea) Level, Time 0-60, Time 1/4 mile, Torque, Torque Solenoid Pressure, Trans Temp, Turbo Boost.
Manual http://www.edgeproducts.com/product_...manual-347.pdf
Rich
KC Stage 3, FF 190/75, UCF Ported O-Ringed Heads, Warren Comp Plus Transmission, ARP, Sinister Up & Charge Pipes, ODAWG Ported Intake, Atlas 40, IPR EGR Delete, DD RR Kit , Fass 200, BD Exhaust, Mishimoto CAC & Radiator, BPD Water Pump, OUO Bars, MBRP 4 TB SS Duals, Sinister Coolant/Oil Bypass Edge CTS w/EGT & FP, SCT X4, DC Power 190 AMP, Hellwig Sway, No Limit Cold Air, Beans Sump, Gearhead Tunes
2006F350 is offline
post #3 of 6 Old 07-13-2012, 04:01 AM
Thanks,
Randall
If you have the LCD display in your truck, you can see the current gear that way. I had the CTS for a short period of time and liked it. The factory EGT sensors are all post turbo, so you'll have to do math to get a rough idea of what the in-cylinder temps are. I liked the soot concentration and trans temp PIDs the best. Also had a red indicator for when the truck is in regen.
2011 F250 XLT CCSB, 6.7 PSD
jeffc is offline
post #4 of 6 Old 07-13-2012, 06:15 PM
I watch egt 1and 4 boost coolant temp and soot concentration
2011 Ford SD250 6.7 Lariat interior group 20"s chrome package, White/beige Black Leather, 3.55's, ARE Topper, Bed Rug, EDGE CTS
99 SD250 sc swb 4x4 psd auto 3.73ls,lariat, oxford white, leather, loaded, curtis snowplow 125,000 miles
rpres62 is offline
post #5 of 6 Old 07-13-2012, 07:08 PM Thread Starter
Thanks guys, I do have the LCD screen but, what do I have to do in order to see wat gear it is running in. I just got the truck so I really haven't had much time to see how all of the gadgets work.
Randall
Boss 302 is offline
post #6 of 6 Old 07-15-2012, 08:00 AM
Push the + on the shifter
sleepersilverado is offline
