Tuned EGT questions - Ford Powerstroke Diesel Forum
post #1 of 13 Old 06-28-2012, 01:04 PM Thread Starter
Scubamax's Avatar
Tuned EGT questions
I've got the Mini Max, MBRP 4" with DPF delete with muffler and EGR blocker(EGT). When I put tuner on "hot", my EGT's spike after around 10 seconds and it starts Defueling. This seams excessive to me. What can I do to lower my EGT to make a full 1/4 mile pull without going over 1450deg? I was thinking of CAI, but I'm almost convinced that's a waste of money. Any thoughts?
Also, even on the "no power added" setting, my truck still blows smoke till the turbo lites up. Is that normal?
94% of all Dodge Cummins trucks from1992 through 2012 are still on the road today..... The other 6% made it home.....
2012 F250 Lariat FX4
H&S Mini Maxx
Deleted MBRP 4" W/Muffler
EGT blocker plate
If it still runs when you delete it, you don't need it!
Scubamax is offline
post #2 of 13 Old 06-28-2012, 10:12 PM
ABP
Mine smokes on the no power as well. The one thing I don't like about the tuner is the loss of low end. I feel like they are dumping way too much fuel down low.
2012 F250 Lariat CC/SB 4X4-traded
2013 Ram Mega Cab 4x4 Long Horn-traded
2015 F250 King Ranch CC/SB 4x4-happy to be back
ABP is offline
post #3 of 13 Old 06-29-2012, 06:16 AM
Brief moments over the coveted 1250* is not going to hurt anything. My dodge used to sit on the peg at 1500* and not come off for a few seconds after I let off and it's still running great with 0 blow by even after 220k miles. I've got friends that peg 2000* by the 1/8 and they don't let off till the run is over and none have hurt an engine. Turn the refueling off when your racing and just let her run.
2011 6.7 FX4 Lariat
TheBoss is offline
post #4 of 13 Old 06-29-2012, 07:32 AM
Bryce18's Avatar
Quoted: 19 Post(s)
I notice the same thing. for a 1/4 mile run my truck usually starts defueling between 60-75 mph.
'11 F250, 6.7 PSD, 3.55 gears, FX4 CC,SB,KR,5% tint, Hankooks w/ moto metal 959's, B&W hitch
Mods
S&B CAI
H&S MINI
5" mbrp strait pipe
H&S EGR block offs
VIAIR OBA
U.P.train horns
Bryce
Bryce18 is offline
post #5 of 13 Old 07-03-2012, 08:19 AM Thread Starter
Scubamax's Avatar
I understand what your saying, but aluminum starts melting at 1350 deg. My ol duramax didn't hit these temps till well after the 1/4 mile mark. Does anyone have any input on a CAI and what it did for there EGT's? I will not let my trucks EGT's go over 1450.... It's not worth it for me, but if there's a way to do it safely! lol
H&S Mini Maxx
EGT blocker plate
Scubamax is offline
post #6 of 13 Old 07-03-2012, 07:20 PM
bearscat's Avatar
Is the DPF delete an open exhaust or does it still have a kitty? My buddy turned one if his pistons onto a convertible running the 1/4 on his d-max, I think he was hitting around 1600?
bearscat is offline
post #7 of 13 Old 07-03-2012, 07:54 PM
You are not going to hurt your pistons by going over 1350* for a few seconds. Mine set on the 1500* peg for over 10sec multiple times and never had blow by or burned oil and has seen over 1300* for 10 years every day of its life for 220k miles. It now currently has 240k miles and still no motor issues.
And for reference, the common rail dodges are melting pistons at 1200* egts because the burn is so efficient that the injectors are basically becoming blow torches. So don't always trust your egts to keep your engine together.
2011 6.7 FX4 Lariat
TheBoss is offline
post #8 of 13 Old 07-03-2012, 10:53 PM
Hawco's Avatar
i'm usin the mini maxx with the egr blocker (EGT kit) as well,
with the programmer gauge settings should it be set on pyro 1 to
monitor the EGTS? just want to make sure i got it on the right setting.
HAWCOFREESTYLE.COM
2012 F350 Larait FX4
22" Fuel Wheels
35" Nitto Terra Grappler Tires
Pro Comp Leveling Kit
AFE Stage 2 Intake
AFE 5inch Exhaust
H&S Mini Maxx
Recon Lighting
Hawco is offline
post #9 of 13 Old 07-04-2012, 08:24 AM Thread Starter
Scubamax's Avatar
So your saying that 1500 deg will not hurt my motor, but 1200 deg can melt the piston? come on dude.... It's not a crap shoot when you lay on the throttle. I don't drive a common rail dodge. I know nothing about them. I drive one of the most technically advanced diesel truck engines made today. It's also one of the most expensive to repair. My chances of having a 200k + mile truck are much better if I keep my EGTs down. Maybe I'm not asking the right questions. What about an upgraded innercooler?
H&S Mini Maxx
EGT blocker plate
Scubamax is offline
post #10 of 13 Old 07-04-2012, 12:13 PM
No. What I'm saying is the numbers don't matter. And the common rail dodge uses the same fuel system we do, we just have different style injectors. Still 20,000+psi fuel pressure being fired multiple times in a cylinder to produce a super efficient burn. So even though the gauge says the egts are below the magical number, the pistons are still melting. But then you have other situations where your way over the magical number with nothing ever happening. In a drag race your egts are useless. If your towing 10,000lbs up a mountain pass then keep an eye on them.
2011 6.7 FX4 Lariat
TheBoss is offline
