The Cheaper approach to Engine Tuners? - Ford Powerstroke Diesel Forum
post #1 of 9 Old 05-27-2012, 01:11 PM Thread Starter
Hi All,
Now Iíve chalked up my first 5K miles Iím interested in getting the most from the engine of my 6.7.
I notice that swapping the air intake etc appears not to be required, and I am not wanting to swap out the exhaust just yet. All that really is left as an option is a tuner box to optimize fueling.
Main aim is to clean up the fueling, improving throttle response, economy and "drivability". Huge power gains are not first on the list.
Iíd be interested in some feedback on the following products Ė which all appear to do something slightly different, but donít get much forum space:
1. TS Performances Power Play MP-8 ~$360 USD, doesnít leave any trace on the computer
2. Diablo Sport Extreme Power Puck ~$290 USD (I've found very very little about this on the Web specific to the Ford 6.7)
3. Edge Products EvoHT ~$380
You can tell I am cheapÖ. But I suspect Iíd stretch to a Edge Evolution CS, just to allow me to see whatís going on (I assume the tunes are the same as the EvoHT) if the Edge was the way to go.
Iíd love to hear feedback/ comments
Cheers
FredZZ is offline
post #2 of 9 Old 05-27-2012, 01:22 PM
jesilvas's Avatar
Quoted: 2 Post(s)
Idk much, but I can tell you that the reason the Diablo and the other tuners are cheap and aren't discussed much is because they really aren't that great compared to H&S, Spartan, and the other custom tuners.
And, correct me if I'm wrong, but a DPF/DOC delete is going to get you the most out of the motor. It needs to breathe.
That's just what I've learned from reading.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #3 of 9 Old 05-27-2012, 03:34 PM
srjd's Avatar
Quoted: 2 Post(s)
If your looking for reliability and not willing to get rid of the dpf then you may as well just not touch anything
01/07 Job 1 F350 H&S Tuned. ARP Studs, AFE 4'' straight pipe, EGR delete with elbow, AFE stage 2 CAI, 6'' lift on 37s, 20x12 Fuel Nuts two piece, Sinister coolant filter, CCV Mod, Projector headlights HID kit
srjd is offline
post #4 of 9 Old 05-27-2012, 04:14 PM
barobbin's Avatar
Quoted: 3 Post(s)
im pretty sure any tuner will leave a trace on these computers. someone correct me if i am wrong
barobbin is offline
post #5 of 9 Old 05-27-2012, 05:10 PM
Bryce18's Avatar
Quoted: 19 Post(s)
On a truck that is this expensive do you really want to use a cheap tuner?
My opinion is save up and buy a H&S mini max or a Spartan tuner that monitors many parameters and run dpf present tuning.
And then when you decide to run deleted tune, (no dpf, DEF, and no egr) you already have a tuner that has the capability.
Like said above, there isnt much feedback on the tuners you mentioned because they dont even compare to H&S or Spartan who have both proven themselves.
Thats just my opinion and advice, but in the end its all up to you
Sent from my DROID2 GLOBAL
'11 F250, 6.7 PSD, 3.55 gears, FX4 CC,SB,KR,5% tint, Hankooks w/ moto metal 959's, B&W hitch
Mods
S&B CAI
H&S MINI
5" mbrp strait pipe
H&S EGR block offs
VIAIR OBA
U.P.train horns
Bryce
Bryce18 is offline
post #6 of 9 Old 05-27-2012, 06:07 PM
Senderofan's Avatar
I'm not sure you're going to be able to achieve your stated goals by using one of the tuners you list. If you want to leave the DPF on...I would recommend an H&S tuner at a minimum....and probably go for the KEM green card. It seems these motors return their best fuel economy with the larger tunes ( highest hp settings.) In terms of "Cleaning" things up...the EGR delete takes care of the intake side....removing the DPF takes care of the restrictive exhaust side. Removing the restrictions makes for a more efficient package...you will see improvements across the board.
Ultimately it's up to you....but for the most part...you get what you pay for. You have to decide at what point you'd be satisfied. Just because a truck is deleted and runs a big tune doesn't necessarily equate with doing burnouts at every stop sign. Some want the engine to breath better, not forcing it to ingest soot and to maximize fuel economy.
Good Luck,
Wayne
P.S.
I purchased a Diablo for my father's Duramax. This unit was inexspensive....but didn't perform as well....or have the support behind it like an H&S or Spartan.
2011 F 350 Lariat Ultimate CC, SB 4x4 with 6.7 PowerStroke. Sterling Grey Metallic. Stock rims, tires. Shocks are Bilstein 5160's...what an upgrade over stock!
2013 PW Boss Mustang with aftermarket fully adjustable suspension, Team Dynamic 18"x10" race wheels and 305mm Continental race slicks at all four corners....O/R X pipe, 84.5mm TB, Airaid cai, 47 lb injectors...tuned by AED...Life is fun in this vehicle!
Senderofan is offline
post #7 of 9 Old 05-27-2012, 06:34 PM
You bought a $50,000+ truck that has a $15,000+ engine and want to run a cheap tuner? Really?
Andrew010 is offline
post #8 of 9 Old 06-07-2012, 02:27 PM
First 6.7 PS Destroyer
mysticblu999's Avatar
Quoted: 2 Post(s)
Cheap but good approach would be SCT hand held or XRT pro
Sent from my SAMSUNG-SGH-I717 using AutoGuide.com App
2011 F250 6.7 4x4 CC Lariat
6" 4-link BDS
22" Fuel Hostage
37" Toyo MT
H&S BLACK MAXX,
5" MBRP straight pipe
AMP Steps
Truck pics ---->
mysticblu999 is offline
post #9 of 9 Old 06-07-2012, 02:33 PM
Franchi's Avatar
Feedback Score: 22 reviews
This. Doesnt have to be expensive if you do your research ahead of time. But at same time, dont cheap out on a mod like this. lol
Franchi is offline
Tags
tuner diablo edge mp-8
