Modification gains - Ford Powerstroke Diesel Forum
post #1 of 8 Old 05-25-2012, 09:48 AM Thread Starter
blacksuperduty11's Avatar
Modification gains
I have seen a lot of members stating they have performed tuning modifications and deletes. But I have not seen any technical data showing benefits of doing them. What are the real world gains performing each?
EGR delete?
DPF delete?
DEF delete?
Air intake upgrade?
Tuner?
I would be curious to know if anyone has dyno'd their truck after each modification. I not only am interested in HP/ft lbs increases but also would like to know what mpg increases have been seen.
As a side note, I would also like to know each members experience good/bad has been since mod's. I see several reverting back to stock in order to have warranty work performed.
2011 F-350 Lariet CC 4x4
blacksuperduty11 is offline
post #2 of 8 Old 05-25-2012, 09:49 AM
"Stroker 8"'s Avatar
Quoted: 4 Post(s)
Larry
2015 F-350 CCLB DRW, Lariat Ultimate,
2nd Gen. 6.7L "Scorpion" Turbo Diesel,
440HP/860TQ, Torque Shift 6-speed,
Tuxedo Black W/Charcoal Black Int.,
14,000 LB GVWR,
3:73 Gears W/Limited Slip,
17" Polished Forge Alum. Wheels,
BFG All-Terrain Tires,
Factory 5th Wheel/Gooseneck Prep Pkg.,
Spray In Bed-Liner,
Supplemental Cab Heater,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
Engine Block Heater,
9025 Lbs. on the CAT Scales.
"Mack Daddy Scorpion!"
"Stroker 8" is offline
post #3 of 8 Old 05-25-2012, 11:49 AM
factoryflood's Avatar
Egr delete, gets the soot out of your intake.
Dpf delete, gets rid of excess back pressure that forces your turbo and motor to work harder then it should
Def, gets deleted when DPF is deleted
Intake, not seeing much of a benefit on the 6.7s like they were on the 6.4s. The stock box is good for 500whp
Tuner, deletes the dpf, calibrates the motor, ECM, and tcm. Monitors a list of parameters
2012 F350SRW CCSB
H&S Mini Maxx with MCC, Spartan with war hammer(FOR SALE), 5" down pipe back exhaust, AFE Stg 2 Cold Air Intake, 6k 55w HIDS, Eagle Alloys 014 20x9 0 offset wheels, 35x12.50R20 Toyo Open Country AT2 Xtreme, UWS toolbox
Inside- Pioneer AVH3200BT, 2 Kicker CVT 12's, Kicker ZX1000, 4 gague wiring, Custom sub box, 20% tint all the way around
factoryflood is offline
post #4 of 8 Old 05-25-2012, 04:05 PM Thread Starter
Just thought it better to drop it here...
post #5 of 8 Old 05-25-2012, 04:30 PM
MDarrough's Avatar
That post should get you everything you want.
Jeez, what a tude!!
2011 F-350 4X4 Dually Lariat pulling a 2010 Sierra 355QBQ 5er --
MDarrough is offline
post #6 of 8 Old 05-25-2012, 04:40 PM
the egr delete gets the soot out of the intake elbow, lets motor perform better, have longer life expectancy no mileage gains, just extends life of motor
air intake as previously stated not completely need on a 6.7. flows better, filters about the same or slightly worse. some claim mileage gains, you probably won't see any, truck might be touchier on throttle with more air to use.
DPF delete lets truck breath, think of it this way try to shoot a spit ball from a straw with to big of a spit ball, its hard to do, this is what your truk has to do. you will see milage gains, but would be limited with towing.
Tuner have to have one to delete egr, and exhaust, or else truck will be in constant regen. This will be your real mileage adder, the bigger the tune, the better the mileage.
The guys response from early was a perfect response that answered every question, i just elaborated on it. You probably scared off multiple other people from replying by blowing up on the first guy that posted and tried to help end of rant
levan4076 is offline
post #7 of 8 Old 05-25-2012, 04:56 PM Thread Starter
I will start with an apology to all especially Flood. Was not my intent to flame on him or anyone else. levan thank you for the additonal input to the previous post... Too many years on another HP forum with a lack of civility. I will chill!
post #8 of 8 Old 05-27-2012, 11:51 AM
Bryce18's Avatar
Quoted: 19 Post(s)
Everything has been pretty much covered above ^^^^^ just by adding a tuner and deleting dpf you will see a great increase in fuel mileage and hp/tq.
My mods are in my signature. Since i deleted, i gained a absolute minimum of 3mpg (empty highway driving).
Highway driving i now see about 19-23 mpg with H&S on "hot" depending on speed.
City driving, (usually stepping on it) haha i see about 15-16mpg.
While towing a 30' goose neck Wilson cattle trailer loaded,(about 15-18k pounds) i usually avg about 14-15mpg with my H&S mini on "mild"
As far as warranty goes, it all depends on dealer. My dealer is mod friendly and they do all my services. But any dealer has to prove your aftermarket parts caused a break or problem before they can void the warranty.
Sent from my DROID2 GLOBAL
'11 F250, 6.7 PSD, 3.55 gears, FX4 CC,SB,KR,5% tint, Hankooks w/ moto metal 959's, B&W hitch
Mods
S&B CAI
H&S MINI
5" mbrp strait pipe
H&S EGR block offs
VIAIR OBA
U.P.train horns
Bryce
Bryce18 is offline
