Removed H&S and returned to stock got CEL - Ford Powerstroke Diesel Forum
post #1 of 34 Old 05-21-2012, 01:00 PM Thread Starter
So I reverted my truck to stock EGR Block Plates removed and DPF back on. Connected all sensors and returned the tune to stock.
I threw two codes that keep coming back. Called H&S and said to check with ford, which I am going to ask them tomorrow. I figured I would ask here as well.
I got
P2047 Reductant Injector Circuit Open Bank 1 Unit 1
P042E Exhaust Gas Recirculating control stuck open
Truck seems to run fine, idles fine etc. I clear the codes with the tuner and they keep coming back..
Anyone know what the deal is ? H&S was installed fully deleted for about 5-7k miles.
mg1098 is offline
post #2 of 34 Old 05-21-2012, 01:28 PM
I got
Maybe this can help narrow down your issues:
P2047
Possible Causes: RDINJPWR circuit open or short
RDINJGND circuit open or short
Reductant injector open or short
P042E
Possible Cause: Damaged EGR valve
May be simply due to accumulation of debris build-up around the valve.
SPARTANDIESEL2 is offline
post #3 of 34 Old 05-21-2012, 01:41 PM Thread Starter
P2047
Possible Causes: • RDINJPWR circuit open or short
• RDINJGND circuit open or short
• Reductant injector open or short
P042E
Possible Cause: • Damaged EGR valve
Thanks does the P2047 mean that the DEF Control plug isn't plugged in ? or something ?
Any clue which plug that might be ??
mg1098 is offline
post #4 of 34 Old 05-21-2012, 02:00 PM Thread Starter
You are awesome.. that for sure was one CEL. Ground fault/open meant i missed a connector.. COnnected it and testing.. however the one for the EGR is probably messed up or clogged..
mg1098 is offline
post #5 of 34 Old 05-21-2012, 02:05 PM Thread Starter
That fixed the ground fault.. EGR still stuck open. Not sure why though
One code down and one to go.
mg1098 is offline
post #6 of 34 Old 05-21-2012, 04:13 PM
LFD132's Avatar
Quoted: 3 Post(s)
Like mentioned above...that seems to be a common code when putting back to stock. The EGR hasn't been used since you tuned it and all the soot builds up causing it to stick. You can try to get to it and clean it. That would clear the code.
Sent from my DROID RAZR using AutoGuide.com App
[SIGPIC][SIGPIC]2013 F250 FX4
LFD132 is offline
post #7 of 34 Old 05-21-2012, 04:35 PM
Hawkeye Diesel's Avatar
There was a member on here a while back who returned his truck to stock and had the EGR stuck open code. He took it to the dealer and had his EGR replaced under warranty if I remember correctly. Maybe he will chime in?
[/SIGPIC]2008 F250 Lariat, 8" lift 37x12.5 20 Nittos, Spartan tuned running 275 with an AFE stage 2 and 4" straight pipe. Next up, full EGR and Cooler delete
Proud to be a Union Steamfitter
Hawkeye Diesel is offline
post #8 of 34 Old 05-21-2012, 04:45 PM Thread Starter
Thanks Guys..
That is probably exactly what it is.. If I knew more about the internal EGR Valve and what it looks like and how it operated I would try and clean it myself..
mg1098 is offline
post #9 of 34 Old 05-21-2012, 05:21 PM Thread Starter
So I popped the hood and turn the truck on and then off again. I can see what I think is the EGR Valve Plunger opening when I turn the truck off.. Or closing not sure.
So it looks like that part is working.. Anyone know how this actually works?
mg1098 is offline
post #10 of 34 Old 05-22-2012, 08:29 PM
Just put mine back to stock as well. I had to order a new EGR as it was clogged up with soot. I think they said it would be 6 hours for labor.
2015 F-350 Platinum SRW, Carli 2.5 Pintop 2.5" w/ Deavers & Carli Radius Arms, 35X12.50 Nitto Mud Grapplers
DeagonKennels is offline
