How safe are we running H&S on hot? - Ford Powerstroke Diesel Forum
post #1 of 6 Old 05-16-2012, 08:37 PM Thread Starter
I've seen at least one thread where the rods got bent with a tuner only. I run mine on hot most of the time, but I get worried about the rods in my engine. I'd really rather not bend or break any. I'm looking for anyone with input, especially from H&S directly. An actual statistic about major engine damage would be nice if they have one. Thanks!
Chris
2011 F350 4X4 CCSB SRW, King Ranch, 3.55, Mini Maxx, 4 inch exhaust, egr gone, Confederate Diesel turbo kit with a S363 and 0.91 twin scroll turbine housing, and stock air filter.
DirtBikePilot is offline
post #2 of 6 Old 05-17-2012, 10:34 AM
interested also.
svtbolt2001 is offline
post #3 of 6 Old 05-17-2012, 10:49 AM
We have not heard of any major engine failure on the 6.7L platform. The only known issue that now seems to have been resolved by Ford was a turbo shaft failure due to excessive vibration. Other than that, the 6.7L has been a solid engine platform. Now if somebody will step up and build a better CP4 pump or twin pump kit we will start testing the limits!
H&S Support is offline
post #4 of 6 Old 05-17-2012, 12:41 PM
I was wondering if you shared the sentiment that rods will be a limiting factor. We've seen a couple failures, and a couple pictures, but I was curious as to your take on the situation.
My thoughts are that its a little early to tell given the realitively limited number of failures, and limited number of trucks in that HP range. Seems like not many are talking about it. I mean when we had these kinds of failures in the 7.3s alot of testing went in before anyone threw in the towel.
Is anyone considering CP testing, or an indepth analysis of a stock rod under controlled circumstances, maybe stress testing of a rod outside of the engine? Now this isn't something I would expect H&S to do necessarily, but was more curious as to if any individual or shop out there is doing this type of an analysis.
Maybe it would be more obvious to me if I held a piston/rod assembly from a 6.4 in one hand and one from a 6.7 in the other. I'm just not totally totally convinced yet.
2011 F-350 ECSB 4x4 Lariat Sterling Gray Metallic. 51,000 mi
Mods: Silver Star Ultra bulbs
Removed Photo Sticker Violates TOS
mrplowjr73 is offline
post #5 of 6 Old 05-17-2012, 09:45 PM Thread Starter
Thanks for the replies, especially from H&S!! I really appreciate it. The rod failure I'm thinking of was on a spartan tuned engine. It's right here: engine knock - PowerStrokeNation : Ford Powerstroke Diesel Forum
I feel like running the hot tune is right at the limits of the stock internal parts. Hopefully I'm wrong.
post #6 of 6 Old 05-17-2012, 09:50 PM
2003kingranch's Avatar
SPE grenaded a 6.7 already with a h&S and their twin kit.
[/URL]
[CENTER]2012 King Ranch
22k deleted at 1k
5" FLO-PRO
S&B Intake
Sinister Egr Delete
MiniMax/ SPE Tunes
466/953 on 37's
6" 4 link
37's on 22's
Bags and compressor
RBP mudflaps
transfer tank tool box.
9" 2" poly boss v blade
Should have kept my 6.0.....
2003kingranch is offline
