Beautiful Oil...... - Ford Powerstroke Diesel Forum
post #1 of 12 Old 05-02-2012, 08:11 PM Thread Starter
richc22a's Avatar
Beautiful Oil......
I am 700 hundred miles into my 2nd oil change after an egr/emissions delete.
All I can say is the oil on this 100k + engine looks new. It is not black, it looks like oil!! Not nasty black like a soot strainer...
My injectors, turbo, hp pump...... might last a while....
Driving: 2011 Pale Adobe...F-350 CC 6.7 FX4 3:55-Locking Rear End-Dual Alternators-premium Lariat, moon rf, added wheel flares, 2-tone black base
Picked up 4/29/10 as of 06/20/2012 109,000+miles
richc22a is offline
post #2 of 12 Old 05-03-2012, 06:56 PM
First 6.7 PS Destroyer
mysticblu999's Avatar
Quoted: 2 Post(s)
2011 F250 6.7 4x4 CC Lariat
6" 4-link BDS
22" Fuel Hostage
37" Toyo MT
H&S BLACK MAXX,
5" MBRP straight pipe
AMP Steps
Truck pics ---->
mysticblu999 is offline
post #3 of 12 Old 05-06-2012, 08:17 PM
Nice eh? I'll add that while the rest of the engine might last longer, the fuel pump and injectors never come into contact with any engine oil.
2011 F350 4X4 CCSB SRW, King Ranch, 3.55, Mini Maxx, 4 inch exhaust, egr gone, Confederate Diesel turbo kit with a S363 and 0.91 twin scroll turbine housing, and stock air filter.
DirtBikePilot is offline
post #4 of 12 Old 05-06-2012, 08:50 PM Thread Starter
richc22a's Avatar
The electronic injectors are activated or “fired” by a driver module, which is activated by the engine’s powertrain control module (PCM). This information is provided to the PCM from a cam sensor located above the harmonic damper in the front timing cover. The cam sensor is a hall effect switch that tells the powertrain control module what cylinder is ready for injection.
Oil Fired Injectors..
When the electronic injector is energized from the injector driver module an electronic solenoid mounted on the injector opens a poppet valve. High-pressure oil from the HPOP flows into plunger, which moves downward, increasing fuel pressure and opening the nozzle. Fuel is then injected into the combustion chamber at pressures as high as 18,000 psi.
now, about that blinker fluid you thought was a joke...!!
richc22a is offline
post #5 of 12 Old 05-06-2012, 09:08 PM
atvrider93's Avatar
Quoted: 8 Post(s)
Exactly right!................for a HEUI engine(7.3 & 6.0)
1996 F350 4x4 CCLB-- I'll miss her
1996 F350 4X4 RCLB zf5 213K
6637
OBA w/horn
DE 5"
PHP tunes
Mud Country 315/75/16
2008 Wr250X
Originally Posted by belz View Post
There u go Tom. John may not be sexy, but he can tutor you, lol.
atvrider93 is offline
post #6 of 12 Old 05-06-2012, 09:17 PM
Quoted: 48 Post(s)
you ran the original oil for over 100k miles?!
drunk on diesel is offline
post #7 of 12 Old 05-06-2012, 09:36 PM
atvrider93's Avatar
Quoted: 8 Post(s)
700 miles.
I'm still trying to figure out what he means by 100K engine
6637
OBA w/horn
DE 5"
PHP tunes
2008 Wr250X
post #8 of 12 Old 05-07-2012, 12:25 AM
srjd's Avatar
Quoted: 2 Post(s)
he means his engine has over 100k on it but on 700km oil it still looks fresh
01/07 Job 1 F350 H&S Tuned. ARP Studs, AFE 4'' straight pipe, EGR delete with elbow, AFE stage 2 CAI, 6'' lift on 37s, 20x12 Fuel Nuts two piece, Sinister coolant filter, CCV Mod, Projector headlights HID kit
srjd is offline
post #9 of 12 Old 05-07-2012, 12:25 AM
srjd's Avatar
Quoted: 2 Post(s)
i meant 700 miles on oil change
srjd is offline
post #10 of 12 Old 05-07-2012, 02:29 PM Thread Starter
richc22a's Avatar
Got it... the oil is not involved in the injector function..!!!
richc22a is offline
