H&S Pyro 1 reading & temps - Ford Powerstroke Diesel Forum
post #1 of 12 Old 05-02-2012, 02:47 PM Thread Starter
SouthernF250's Avatar
Cool H&S Pyro 1 reading & temps
I have a 2011 F250 with the mini maxx and factory everything (exhaust included). What is the Pyro 1 temp?? What is Pyro 1 actually reading?? I never installed the pyro from H&S and maybe due to my own stupidity or lack of knowledge from others but I canít get my questions answered. Thanks for the help.
2011 F250 CCSB 4X4 Lariat with ProComp 6" Lift, Bilstein 5125 shocks, Bilstein 5100 steering damper, 37" Nitto Terra Grapplers, 20" Fuel Hostage Wheels Chrome, PMF Stage 2 traction bars, Rigid Industries dually diffused back up lights, Titan 50 gallon fuel tank
SouthernF250 is offline
post #2 of 12 Old 05-02-2012, 03:12 PM
Bjolls's Avatar
If you didn't hook up a pyro (exhaust gas temperature) then pyro 1 is reading nothing.
2014 F350 Lariat FX4 - 22's on 35's - Recon Lights - AMP Steps - More on the way
Bjolls is offline
post #3 of 12 Old 05-02-2012, 03:38 PM
LFD132's Avatar
Quoted: 3 Post(s)
You best and easiest route to go would be blocker plates for your EGR. One you do that you can start reading your temps through the tuner. Not many people use the pyro on the fords.
Sent from my DROID RAZR using AutoGuide.com App
[SIGPIC][SIGPIC]2013 F250 FX4
LFD132 is offline
post #4 of 12 Old 05-02-2012, 04:42 PM Thread Starter
Well I hooked up the H&S tuner per the instructions without the pyro and I get a temp reading when itís turned on. I'm assuming its reading from wherever Ford has a pyro from the factory????
post #5 of 12 Old 05-02-2012, 08:05 PM
richc22a's Avatar
An accurate reading of your egt's is critical if you are towing, or heavy into the throttle. Stock, I have to push it to break 1000 degrees, on hot.. I can hit 1200 degrees real quick. I visited a diesel shop with a shelf full of melted pistons from too high egts...
Driving: 2011 Pale Adobe...F-350 CC 6.7 FX4 3:55-Locking Rear End-Dual Alternators-premium Lariat, moon rf, added wheel flares, 2-tone black base
Picked up 4/29/10 as of 06/20/2012 109,000+miles
richc22a is offline
post #6 of 12 Old 05-02-2012, 09:35 PM
The reading you see is from a sensor in the DPF. Once you do a DPF delete, you need to relocate one of the sensors to the front of the engine using 2 EGR blocker plates spoke of by one of the earlier posts. It can get confusing If it's not explained just right. Let us know if you have any further questions!
H&S Support is offline
post #7 of 12 Old 05-03-2012, 04:13 PM Thread Starter
That answered my question. Thanks for all the replies.
post #8 of 12 Old 05-04-2012, 07:44 AM
I just did my delete last night and I haven't installed the blocker plates yet and now I am getting a crazy reading for pyro 1... What is it?
Sent from an apple.
4EverBoosted1 is offline
post #9 of 12 Old 05-04-2012, 05:12 PM
Pyro 1 reads the sensor in the exhaust and since you removed the exhaust, the sensors are also gone and you will get really strange readings.
2011 F-350 CCSB
powerstroke43 is offline
post #10 of 12 Old 09-03-2016, 04:20 PM
Same situation- and I'm getting up to 1990* on my Pyro1 using factory pyro setting.
On tow tune.
What the heck is it reading that is that hot?
00buck is offline
