H&S MiniMaxx and KEM Green Card (sorry long post) - Ford Powerstroke Diesel Forum
post #1 of 5 Old 04-01-2012, 11:08 AM Thread Starter
I was researching a problem I had last night and now I have questions. I have 3800 miles on my truck and it has had the tuner for 1000 miles. I like having the best of both worlds, power and increased mileage so after reading about the green card I had to get one. I loaded the card and programmed it for level 5 not realizing that I would no longer have the on the fly adjustments. Bummer but I can live with that. First off the truck is a stock CCSB F350 4wd. I haven't had a single problem with it until last night on the way home it started acting up. It was a short 30 minute drive, the coolant was up to temperature and everything seemed ok until about 25 minutes in. It stated surging under light throttle, hesitating while shifting, and when I came to a stop it was loping real bad. Light throttle acceleration was rough for a couple of hundred rpm then smoothed out. Back of the throttle and it started loping again. I got home and started looking into it and the only thing I'm finding is the turbo surge at low rpm/high gear problem. (For what it's worth my 350 doesn't do it but the 550 we have does). So on to the couple of questions I have. I saw where people were mentioning their boost levels going to 30+ psi. While stock I only saw 22, and with the H&S tunes it was still 22. The KEM tune brought it up to 26psi but I also noticed the Pyro1 temp dropped quite a bit from before. Has anyone experienced the same problem I saw? Does the boost I'm seeing make sense? Should the Pyro temp have dropped a few hundred with the KEM tune? Am I just nuts and paranoid? OK forget the last question. For now I'm going back to stock then I'll reload the H&S tune, then the KEM making sure it runs OK for a few days in between.
ScooterKrunch is offline
post #2 of 5 Old 04-01-2012, 07:26 PM
TommysDiesel's Avatar
I'm running KEM and i also had the low rpm surge and truck choking. Spoke with KEM and i will meet with one of the guys one day this week. Give KEM a call they also stand up for their products like H&S
TommysDiesel is offline
post #3 of 5 Old 04-01-2012, 09:09 PM
Bryce18's Avatar
Quoted: 19 Post(s)
Not sure about your pyro temps decreasing. But for your turbo question. I only saw a max of 22lbs with stock exhaust. Now I see 33lbs with H&S and deletes.
Sent from my DROID2 GLOBAL
'11 F250, 6.7 PSD, 3.55 gears, FX4 CC,SB,KR,5% tint, Hankooks w/ moto metal 959's, B&W hitch
Mods
S&B CAI
H&S MINI
5" mbrp strait pipe
H&S EGR block offs
VIAIR OBA
U.P.train horns
Bryce
Bryce18 is offline
post #4 of 5 Old 04-01-2012, 09:30 PM Thread Starter
I'm going to call KEM but I may not get time for a while. Tommy let me know what you find maybe it's a similar problem with the two tunes. Exhaust is one of the things I was thinking with the boost. Pyro 2 is normal, but the highest I saw Pyro 1 was about 160 and that was sitting at a red light. While driving it was below 100. I have to convert the video to post it here, but here is a linkhttp://db.tt/WtZeQl6M to it.
post #5 of 5 Old 04-02-2012, 07:06 PM Thread Starter
I have some new information. I reloaded the H&S tunes and decided to try it out before returning to stock. Everything is working perfectly fine. Temps are back to what I saw before and no more idle issue. I think I'll leave it be until I can get a hold of KEM and see what my problem is.
