MBRP DPF delete install question - Ford Powerstroke Diesel Forum
post #1 of 21 Old 11-26-2011, 10:49 AM Thread Starter
TXGold's Avatar
I installed my DPF delete downpipe back exhaust on Wednesday and the intructions didn't mention which way the exhaust gets installed. Initially I thought having the MBRP logo going left to right with the flow of exhaust would make sense but when you look inside the muffler, there are a bunch of little scoops that stick up. If you look from the other direction the "scoops" look a lot smoother and less restrictive, so thats the way we installed it.
Does anyone have a definitive answer on this? I'm wondering if this is what may be causing a high Pyro reading.
2014 Ram 2500 MC Limited Black/Black, 295/65R20 Toyo AT2Ext's, Thuren 2.5 Springs, Fox/Thuren 2.0 ITP Shocks
TXGold is offline
post #2 of 21 Old 11-26-2011, 10:55 AM
Rob
Rob's Avatar
Quoted: 2 Post(s)
High pyro could be the tune you're running. Not sure really. What level tune are you running?
Audentes Fortuna Juvat
(Fortune Favors The Bold)
The Org. Staff reserves the right to
move, modify, delete or merge threads/posts
at our discretion, without explanation
at any time.
Rob is offline
post #3 of 21 Old 11-26-2011, 10:57 AM Thread Starter
TXGold's Avatar
I'm running the 6.7.17 tune and have had it on "no power" since the install because of the problems.
TXGold is offline
post #4 of 21 Old 11-26-2011, 10:59 AM
Rob
Rob's Avatar
Quoted: 2 Post(s)
Any tuning running more HP than stock will produce higher temps. How you drive with those tunes also affects the temp. Do you have a heavy foot? Lol
at any time.
Rob is offline
post #5 of 21 Old 11-26-2011, 11:28 AM Thread Starter
TXGold's Avatar
Yes I do usually. But the Pyro never read anything crazy like this with stock exhaust. Once I installed the exhaust the programmer was acting crazy from the beginning so I never got into the throttle. And I'm currently so worried about the temps I'm driving like there is an egg on the pedal.
Any ideas about exhaust direction for the MBRP muffler?
TXGold is offline
post #6 of 21 Old 11-26-2011, 11:34 AM
Retired
Sgt93's Avatar
I don't know what to tell you. Did you buy the EGR blocker plate kit as well? If so, take that probe out and try anther probe from the DPF. That is not right at all.
2015 Ford F350 King Ranch SRW SB 4x4 loaded, RetraxPro, Andersen Rapid Hitch.
Ordered: 04/29/14
Built: 05/20/14
Delivered: (projected 06/04/14)
2013 Jeep Rubicon Unlimited
SOLD 2011 Ford F250 Lariat 6.7 PS CC 4x4 SB 3.55 with a bunch of crap.
Sgt93 is offline
post #7 of 21 Old 11-26-2011, 11:40 AM
Rob
Rob's Avatar
Quoted: 2 Post(s)
What kind of temps are we talking about? Is there a huge fluctutaion while driving? You have to realize that more fuel = more heat nad cylinder pressure. what level of HP is the tune adding? I dont know what the 6.7.17 is rated at.
at any time.
Rob is offline
post #8 of 21 Old 11-26-2011, 12:13 PM
6.0L Stroker's Avatar
All those scoops do is quiet the exhaust depending on which way you install the muffler. If you installed them with the air flowing over the bumps that would be the loudest. With the scoops facing forward should be quieter.
2011 F350 CC/SB Bronze and Gold KR tinted windows, spray in bedliner. MBRP 5in filter back with 6in tip and Mini Max. S&B Dry Intake, TGC Dual Stabalizer.
Sold 2004 Ford F-350, cc/lb Lariat, Procomp 6.5 lift with 37/13.5/17 Toyo Mts, Id tuned Ficm, Bully Dog Triple Dog, MBRP all the way back,
6.0L Stroker is offline
post #9 of 21 Old 11-26-2011, 12:15 PM
Sgt. Do you have the blocker plates for monitoring egt? Or did you just turn your sensors off for pyro??
post #10 of 21 Old 11-26-2011, 02:04 PM
Retired
Sgt93's Avatar
I have the blocker plates as I have posted.
Ordered: 04/29/14
Built: 05/20/14
Sgt93 is offline
