Installed exhaust and .17 update on MM have problems - Ford Powerstroke Diesel Forum
post #1 of 4 Old 11-24-2011, 07:22 AM Thread Starter
TXGold's Avatar
Not sure what is going on but all of the sensors and urea flange were disconnected and then the stock exhaust dropped. Installed the new dpf delete exhaust and none of the sensors from the old exhaust were re used(is this correct?). I tightened everything down got the tip were I wanted it and then started the h and s software update version 6.7.17.
I had problems with my old sd card and updating it on my Mac so I went ahead and bought a brand new 2GB sd card. After extracting the full download I transferred everything over to the new card and didn't get any errors. I then updated the firmware and followed the on screen prompts correctly. Then I installed the update.
After doing all this I took the car for a spin and the programmer would not let me put the tune above no power, initially. After driving steadily at around 40 the MM stopped chirping and put the power on mild then wild then hot all on its own. Then when I gunned the power it dropped to no power and started chirping all over again.
Between this and the unit not turning off when the car is off and the issues with updating it before I'm getting tired of this **** and about to switch brands. I don't trust this thing with my $15k engine. Another thing is how the heck do they eliminate all of the factory sensors off the old stock exhaust and still have enough parameters to tune and run the engine correctly? I don't even think there is a single sensor after the turbo.
Your help is appreciated as I'm out of town and have to drive back tonight and worried about drivin and the tune not being correct.
2014 Ram 2500 MC Limited Black/Black, 295/65R20 Toyo AT2Ext's, Thuren 2.5 Springs, Fox/Thuren 2.0 ITP Shocks
TXGold is offline
post #2 of 4 Old 11-24-2011, 07:28 AM
"Stroker 8"'s Avatar
Quoted: 4 Post(s)
subscribed.
Larry
2015 F-350 CCLB DRW, Lariat Ultimate,
2nd Gen. 6.7L "Scorpion" Turbo Diesel,
440HP/860TQ, Torque Shift 6-speed,
Tuxedo Black W/Charcoal Black Int.,
14,000 LB GVWR,
3:73 Gears W/Limited Slip,
17" Polished Forge Alum. Wheels,
BFG All-Terrain Tires,
Factory 5th Wheel/Gooseneck Prep Pkg.,
Spray In Bed-Liner,
Supplemental Cab Heater,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
Engine Block Heater,
9025 Lbs. on the CAT Scales.
"Mack Daddy Scorpion!"
"Stroker 8" is offline
post #3 of 4 Old 11-24-2011, 09:14 AM Thread Starter
TXGold's Avatar
Could it be that I need to turn the 1st Pyro OFF in the defueling menu?
When it is making the chirps and **** it has a message that says Defueling Pyro 1, then goes to no power.
Since the install, Pyro 1s temps are from 2050 to 2450 degrees. This can't be right??? They used to go as low as 165 degrees in cruise.
I remember along the way hearing that the Pyro doesn't do anything unless you buy a egr block plate with bung and put a pyro in there.
Am I correct that Pyro 1 isn't monitoring anything? If so I should probably turn off Defueling for Pyro 1.
TXGold is offline
post #4 of 4 Old 11-24-2011, 06:47 PM
Hawkeye Diesel's Avatar
if you did not use the factory pyro option, by moving one of your pyro's from the DPF into your EGR blocker plates, or buy a Mini Maxx with the Pyro and put that in your EGR blocker plates, then yes, you will need to turn off your Pyro 1 defuel. It sounds like you're getting inaccurate pyro readings, and I can only assume that you did not do the EGR Block off along with your tune, if so, there are no sensors reading to your MM.
[/SIGPIC]2008 F250 Lariat, 8" lift 37x12.5 20 Nittos, Spartan tuned running 275 with an AFE stage 2 and 4" straight pipe. Next up, full EGR and Cooler delete
Proud to be a Union Steamfitter
Hawkeye Diesel is offline
