6.4 or 6.7? - Ford Powerstroke Diesel Forum
post #1 of 21 Old 11-20-2011, 06:41 PM Thread Starter
SixNine's Avatar
6.4 or 6.7?
I have a 08 crew cab dually, 2 wheel drive, RCD 450 tune, intake, 5" exhaust. I could have the opportunity to buy a 6.7, so I'm tryin to get a list together. Here it is
afe intake, stage 2 or that magna force?
Prolly go with 5" exhaust
Reading alot about h&s on these trucks, is there any other tuner to consider?
The trucks a crew cab 2 wheel drive, single rear wheel, how much better will it run then my 08?
How much difference is there, as far as power goes, in having dual wheel versus a single?
what can these transmissions hold compared to the 6.4 trans?
any help, suggestions, advice is greatly appreciated, thanks
SixNine is offline
post #2 of 21 Old 11-20-2011, 07:09 PM
Bryce18's Avatar
Quoted: 19 Post(s)
Well, I had an 08 6.4 and power wise, the 6.4 doesn't even compare to the new 6.7! Not to mention the way better fuel economy that I have experienced with the 6.7 compared to the 6.4,
and to your question about single rear wheels compared to a dually, my opinion is if your always towing gooseneck or 5th wheel trailers duallys are the way to go. I have single rear wheels on mine and it does not struggle one bit towing a loaded 28ft stock trailer though.
About the programmers, I myself just ordered the h and s mini maxx because of all the good things and cecommendations I received about them.
And to your question about the 6.7's tranny I prefer the tow haul mode in drive "D", and the ability to shift through the gears in the manual mode "M" when towing.
'11 F250, 6.7 PSD, 3.55 gears, FX4 CC,SB,KR,5% tint, Hankooks w/ moto metal 959's, B&W hitch
Mods
S&B CAI
H&S MINI
5" mbrp strait pipe
H&S EGR block offs
VIAIR OBA
U.P.train horns
Bryce
Bryce18 is offline
post #3 of 21 Old 11-21-2011, 04:12 AM
George C's Avatar
Stock to stock, go with the 6.7L.
After that, the 6.4L is twice the engine.
The 6.7L lacks miserably in lift pump potential, fuel flow potential and boost potential.
You can easily dial up 600/1,200 power numbers with the 6.4L, the 6.7L does not have the hardware to touch the 6.4L in any way when tuned.
2008 F-350
KEM 345 tuned.
George C is offline
post #4 of 21 Old 11-21-2011, 09:58 AM
matty21's Avatar
The. 6.4is faster so far, bu for the 6.7 with the H&S were seeing ~500 hp ~1100 torque on just the hot tune with a .88 nos jet ,~600 and 1250-1300 trq. But it runs out of air and fuel at that point as far as I've tested, yet I'm no pro.nor do I work for H&S when I say we I mean my own shop.
I was thinking of buying another truck and leaving my tuned one with NADP to ramp it up a bit and do some beta testing. I think a new intake manifold and turbo, combo plus a bit more fuel it will put out more
2015 F350 King Ranch
monochrome tuxedo black, every possible option.
Ordered April 30, 2014
Yet to be delivered
2011 F350 KingRanch 6.7L
AFE stage 2 intake
H&S tuner 4" straight pipe
dual 6" MBRP black stacks. DPF, DEF, EGR Delete
ZEX NOS kit with .088 jet
08 Harley Davidson F350
6" lift with 36x15.50x20's
spartan tuned and deleted.
matty21 is offline
post #5 of 21 Old 11-21-2011, 04:19 PM Thread Starter
SixNine's Avatar
Thanks guys, this does help, still stuck, I have my truck the way i want, but i really think the 6.7 could make power with more time, if I keep my 6.4, then it'll get alot more power, if not I'll have to settle with the 6.7 until more power is available, thanks again
SixNine is offline
post #6 of 21 Old 11-21-2011, 04:20 PM Thread Starter
SixNine's Avatar
Matty, I reckon your runnin the H&S on the hot tune? Can you pull with that tune? Hows the trans act?
SixNine is offline
post #7 of 21 Old 11-23-2011, 03:43 AM
George C's Avatar
The 6.4L is gone, but make no mistake, the 6.7L will never stack up.
You will have to change a multitude of expensive, and yet-to-be developed parts just to equal the hardware that came stock from Navistar on the incredible 6.4L.
That's no BS, that's just the way it is..
I always trade at three years, but I am holding on a little longer until more parts come available for the 6.7L. Once you've had real power, it's hard to go backwards.
2008 F-350
KEM 345 tuned.
George C is offline
post #8 of 21 Old 11-23-2011, 04:06 AM
FJuanfiddy mod
Dave's Avatar
Quoted: 10 Post(s)
If you want a rock solid DD/Tow rig that makes great power and gets excellent mileage go 6.7. If your goal is to run it at the track and nothing more stick with the 6.4.
But George always forgets. It was 2 years in before 6.4 tunes were making decent reliable power.
What the 6.7 lacks in air is already being made up for with twin kits.
IMO George should just by the POS Dmax hes been pining for for the last 2 years
Email:
2006 F250 ECSB Lariat 4x4
Edge Insight CTS
Coolant filter
Dave is offline
post #9 of 21 Old 11-23-2011, 05:15 AM
LFD132's Avatar
Quoted: 3 Post(s)
Dave, they twin turbo kits for the 6.7?
Sent from my ADR6400L using AutoGuide App
[SIGPIC][SIGPIC]2013 F250 FX4
LFD132 is offline
post #10 of 21 Old 11-23-2011, 05:22 AM
"Stroker 8"'s Avatar
Quoted: 4 Post(s)
Just outta curiosity, why did Ford go from the 6.4L to the "Scorpion?"
Larry
2015 F-350 CCLB DRW, Lariat Ultimate,
2nd Gen. 6.7L "Scorpion" Turbo Diesel,
440HP/860TQ, Torque Shift 6-speed,
Tuxedo Black W/Charcoal Black Int.,
14,000 LB GVWR,
3:73 Gears W/Limited Slip,
17" Polished Forge Alum. Wheels,
BFG All-Terrain Tires,
Factory 5th Wheel/Gooseneck Prep Pkg.,
Spray In Bed-Liner,
Supplemental Cab Heater,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
Engine Block Heater,
9025 Lbs. on the CAT Scales.
"Mack Daddy Scorpion!"
"Stroker 8" is offline
