FASS/Air Dog - Ford Powerstroke Diesel Forum
post #1 of 6 Old 11-14-2011, 08:35 AM Thread Starter
hw713713's Avatar
FASS/Air Dog
Gents,
I am new to the PS world. Coming from the dark side. 4 cummins over the last 10 years. I have always been a believer in the clean fuel factor. I wanted to know if you guys thought the same way or if Ford did a good enough job with the factory system. I want to keep the warranty and will be planning for at least the first 50,000 keeping it stock. Most dealers on the Dodge side were ok with the clean fuel systems. Is this a concern with warranty? Thanks for your advice in advance. Really like the truck other than the complicateness of the truck. It scares me to pop the hood
Thanks,
hw713713 is offline
post #2 of 6 Old 11-14-2011, 01:43 PM
mor4wd's Avatar
Any changes to the factory fuel system will not go over well with your warranty. IMO the stock system does an excellent job with filtration. The only reason to go with a FASS would be up your supply but you won't really need that until you get into the 600 RWHP range. If you're concerned about it put in a bed tank with a bowl filter and fill your tank through it. Welcome to the .org.
PS if you want to know everything about the truck go to H&S website and grab the PDF for the 6.7. It's written by Ford for the techs, very informative.
2011 F350 Lariat SRW Crew Cab Long Bed 4x4 6.7 H&S Mini Maxx DPF Delete EGR Delete running 265/70/19.5's
Originally Posted by magzne1 View Post
Chevy comercials are like OBAMA, ALL B.S. over promise and under deliver
Originally Posted by trevor73402 View Post
This stuff isn't as simple as tuning your TiVo to record your Jerry Springer re-runs while your out cruising Wal-mart parking lot for transexual hookers.
mor4wd is offline
post #3 of 6 Old 11-14-2011, 01:45 PM
mor4wd's Avatar
Here's the direct link. http://www.hsperformance.com/1/image...67L_Diesel.pdf
mor4wd is offline
post #4 of 6 Old 11-14-2011, 02:25 PM
twin200's Avatar
Originally Posted by mor4wd View Post
Thanks for that link. Got it downloaded
2000 F-350 7.3 4wd cc,dually lariat
afe intake,programmer. rear airbags
2011 F350 6.7 cc,4wd shortbox lariat
Tinted windows Gray bedliner(diy)
Tool box Bull bar
Front aux lights Rear aux lights
Onboard air Train horns
Billet grille LED bed lights
Mike
twin200 is offline
post #5 of 6 Old 11-14-2011, 03:40 PM
Senderofan's Avatar
Originally Posted by hw713713 View Post
Gents,
Thanks,
I had a FASS on my 2002 2500HD. I think the truck ran quieter and I greatly appreciated the added filtration and removal of vapor bubbles in the fuel....which was one of the major theories as to why the injectors failed on the Duramax. If you do a search...many major diesel engine producers did studies on this and what damage occurs ( Cat, Cummins etc.).
My 2011 will have a FASS installed in a couple of weeks. Reading posts about HPFP failures and Ford denying payment because of evidence of water contamination of the fuel......I'm less concerned about voiding the warranty....or warranty coverage than I am of the HPFP failure. Thus I think the extra filtration etc. might just be added insurance. You'll find folks on both sides of the issue.....Who's to say which is right or wrong...don't know. For me....I like the idea of the FASS or AirDog.
Good Luck,
Wayne
2011 F 350 Lariat Ultimate CC, SB 4x4 with 6.7 PowerStroke. Sterling Grey Metallic. Stock rims, tires. Shocks are Bilstein 5160's...what an upgrade over stock!
2013 PW Boss Mustang with aftermarket fully adjustable suspension, Team Dynamic 18"x10" race wheels and 305mm Continental race slicks at all four corners....O/R X pipe, 84.5mm TB, Airaid cai, 47 lb injectors...tuned by AED...Life is fun in this vehicle!
Senderofan is offline
post #6 of 6 Old 11-14-2011, 03:46 PM
Senderofan's Avatar
I lost the links to several of the studies...here's an overview of some of the things I'm referring to:
FTE Diesel.com / Diesel Performance Parts for Diesel Pickup Enthusiasts...
Wayne
