H&S Update 6.7.16 problems - Ford Powerstroke Diesel Forum
post #1 of 10 Old 11-01-2011, 09:44 PM Thread Starter
TXGold's Avatar
Earlier today I tried to update to 6.7.16 and when I tried to copy and paste the files onto the SD card i kept getting an error saying there wasn't enough room. I WAS selecting to REPLACE the files so there should have been plenty of room on the 2GB SD card.
I called H&S and they told me that sometimes people have these problems and recommended that I download the FULL program and replace all of the SD contents. When I tried that I was not able to put the contents onto the card. I ended having to reformat the card and then I was finally able to put the FULL program onto the card.
When I went to install and update the unit, the Mini Maxx said something like "Can not find SD Card. Please reinsert and try again." I tried about ten different times, trying to turn the car off completely, unplugging the programmer and nothing has worked.
I did have to rename the SD Card after the reformat. I forgot the original name of the card before I deleted it so I just named the SD card "MINI MAX", and after a little googling I noticed that it probably should be named "Mini Maxx." That has been changed but I have yet to see if this is a fix.
I didn't find ANYTHING at all on any of the forums so even though this may be an easy fix, I wanted the next guy out there to be able to find some info.
TXGold
2014 Ram 2500 MC Limited Black/Black, 295/65R20 Toyo AT2Ext's, Thuren 2.5 Springs, Fox/Thuren 2.0 ITP Shocks
TXGold is offline
post #2 of 10 Old 11-02-2011, 08:23 AM
TXGold
Reformat the SD card as Fat16. Fat32 will NOT work. Copy and paste the full SD download to the card.
Should be good to go now. Let us know if you have any more problems.
H&S Tech is offline
post #3 of 10 Old 11-02-2011, 08:58 AM Thread Starter
TXGold's Avatar
My mac with the latest software just has MS-DOS(FAT). Not sure if it's 16 or 32. Any ideas besides get a windows machine?
TXGold is offline
post #4 of 10 Old 11-03-2011, 08:23 AM
Yes, Mac will cause some problems. We have seen it numerous times. I am not a Mac user, so cannot suggest a solution other than trying another computer.
One of our graphic designers here is a Mac user and I will have to go do some playing with an update using his computer. I am sure there is a simple solution, but I just have no experience with that platform.
Good luck!
H&S Tech is offline
post #5 of 10 Old 11-03-2011, 08:38 AM
DSTRBD's Avatar
Good luck!
You mean to tell me people still use that Windows based crap? Next you are going to tell me they use Internet Explorer as well......
Seriously though, it seems more and more people are going with Mac these days. I think it would be well worth your time to make sure everything is kosher with them. Great customer service as always guys!
ICON Vehicle Dynamics | S&B Intakes | MBRP Exhaust | American Force Wheels | Diamond Eye | AFE Intakes | Carli Suspension | Industrial Injection | Garrett Turbos | FASS | Method Wheels | Bilstein Shocks | Airdog | KMC Wheels | Spartan | RSouth Bend Clutch | SCT | Edge Products | ATS Diesel | Bullydog | BMF Wheels | AMP Research | & much more....
DSTRBD is offline
post #6 of 10 Old 11-03-2011, 02:22 PM Thread Starter
TXGold's Avatar
The chip might have gotten fried. Have not been able to get it to work. I remember from our conversation that I need to get exactly a 2GB card not higher not lower. I'll try that and check back.
TXGold is offline
post #7 of 10 Old 11-03-2011, 02:28 PM
Retired
Sgt93's Avatar
You can run Bootcamp (a Windows partition) on your Mac or use a program like Parallels (which is a Windows emulator) which makes a fake Windows environment and will run Windows better than a PC. Bootcamp is free and should be on your mac. Go to "Applications" then "Utilities" and click on the bootcamp icon to get started.
2015 Ford F350 King Ranch SRW SB 4x4 loaded, RetraxPro, Andersen Rapid Hitch.
Ordered: 04/29/14
Built: 05/20/14
Delivered: (projected 06/04/14)
2013 Jeep Rubicon Unlimited
SOLD 2011 Ford F250 Lariat 6.7 PS CC 4x4 SB 3.55 with a bunch of crap.
Sgt93 is offline
post #8 of 10 Old 11-03-2011, 02:29 PM
Retired
Sgt93's Avatar
BTW, I did not have a problem at all downloading and loading the files for my newly arrived Mini Maxx.
Ordered: 04/29/14
Built: 05/20/14
Sgt93 is offline
post #9 of 10 Old 11-03-2011, 09:44 PM
6.0L Stroker's Avatar
Sgt93 do you have the 6.7.16 version? I read on here someone had an issue with it for tire size adjustment and someone said not to update to that one right now
2011 F350 CC/SB Bronze and Gold KR tinted windows, spray in bedliner. MBRP 5in filter back with 6in tip and Mini Max. S&B Dry Intake, TGC Dual Stabalizer.
Sold 2004 Ford F-350, cc/lb Lariat, Procomp 6.5 lift with 37/13.5/17 Toyo Mts, Id tuned Ficm, Bully Dog Triple Dog, MBRP all the way back,
6.0L Stroker is offline
post #10 of 10 Old 11-04-2011, 03:42 AM
Retired
Sgt93's Avatar
I have the latest version as I just downloaded yesterday. If memory serves, that is the one I have.
Ordered: 04/29/14
Built: 05/20/14
Sgt93 is offline
