H&S Guys what sustained PSI do you see and what tune version? - Ford Powerstroke Diesel Forum
post #1 of 17 Old 10-18-2011, 05:43 PM Thread Starter
TXGold's Avatar
What are you seeing for sustained boost? I am seeing 23-24psi sustained and have 6.7.15.
2014 Ram 2500 MC Limited Black/Black, 295/65R20 Toyo AT2Ext's, Thuren 2.5 Springs, Fox/Thuren 2.0 ITP Shocks
TXGold is offline
post #2 of 17 Old 10-18-2011, 05:52 PM
First 6.7 PS Destroyer
mysticblu999's Avatar
Quoted: 2 Post(s)
I should be able to comment pretty soon
2011 F250 6.7 4x4 CC Lariat
6" 4-link BDS
22" Fuel Hostage
37" Toyo MT
H&S BLACK MAXX,
5" MBRP straight pipe
AMP Steps
Truck pics ---->
mysticblu999 is offline
post #3 of 17 Old 10-18-2011, 06:34 PM
Just a quick heads up, a lot of factors will come into play here. Not just tuning version. I see too many random values thrown out on forums, with not much background on what that value means, or how it can be interpreted to help someone reading the thread. So I'll try to steer it into a direction that may help a few people out.
1. Emissions equipment status
2. Power level
3. Barometric pressure
4. Engine RPM for this "sustained level"
5. Torque converter status
6. Coolant temperature
7. Ambient air temperature
Just a few things to keep in mind when looking at numbers! Thanks guys!
My 2011 F-250, DPF delete, 10,000 miles on the Odometer, 2500 ft elevation, Hot power level, Coolant 190, 80 degrees outside.
From a dead stop I will see max boost of 36psi if I watch it through the first 4 gears. The highest boost values will be seen at LOW rpm when the turbo vanes are closed a bit. Once the vanes open the boost will come down to 29-32 psi and hold there until the next shift.
Rolling into it, it depends on the TC status and engine RPM. TC locked, low RPM I will get 34-37 psi (load on the engine from the TC creates an ideal situation for building high boost numbers at low RPM). TC unlocked will yield max values 31-33psi. Once again, boost levels will drop in the higher RPMs as the variable geometry turbo opens and allow the engine to breathe (and keep the turbo from excessive overspeed).
Remember, manifold pressure is a restriction value and not necessarily a measure of horsepower or torque.
H&S Tech is offline
post #4 of 17 Old 10-18-2011, 06:54 PM Thread Starter
TXGold's Avatar
So when I get a dpf delete exhaust installed I should start seeing these higher boost numbers?
I understand you saying boost is a restrictive value BUT it is an inherent trait of power made.
When are the gear numbers going to be up on the display without hitting the up shift arrow? And when can we expect to see an increase in power on of the update tunes?
TXGold is offline
post #5 of 17 Old 10-18-2011, 07:05 PM
Quoted: 2 Post(s)
Thanks for the insight H&S. I appreciate your involvement with the forum
6" 4-link BDS
22" Fuel Hostage
37" Toyo MT
H&S BLACK MAXX,
AMP Steps
Truck pics ---->
post #6 of 17 Old 10-18-2011, 07:10 PM Thread Starter
TXGold's Avatar
^^Yes, thanks for being involved in the community.
TXGold is offline
post #7 of 17 Old 10-18-2011, 07:49 PM
grmreaper's Avatar
I 2nd that statement
2011 F350,CC,LB,Lariat,4x4,FX4,6.7L
2.5" Leveling kit - H&S Tuned and DPF bye bye
6k 55W Bi-xenon Morimoto Mini (H1) Projectors and HID fog lights
18x9 Fuel Hostage Black and Brushed wrapped with 325/65/R18's
JL audio 900/5 AMP, JL CleanSweep, JL 13TW5 sub
Waiting to be installed: EGR delete
On order: S&B intake - now 9 weeks and counting
grmreaper is offline
post #8 of 17 Old 10-19-2011, 04:23 AM
Retired
Sgt93's Avatar
LOL, I suppose you made your decision as well!?
2015 Ford F350 King Ranch SRW SB 4x4 loaded, RetraxPro, Andersen Rapid Hitch.
Ordered: 04/29/14
Built: 05/20/14
Delivered: (projected 06/04/14)
2013 Jeep Rubicon Unlimited
SOLD 2011 Ford F250 Lariat 6.7 PS CC 4x4 SB 3.55 with a bunch of crap.
Sgt93 is offline
post #9 of 17 Old 10-19-2011, 11:35 AM
Yes, the Off-road tuning runs more fuel and more manifold pressure than the street legal tuning.
We are working on the new gear display functions that will default the display to on. No ETA on release yet, but it is on our high priority list right now.
HP on the DPF removed tuning is maxxed out with the stock hardware. Until the aftermarket catches up and provides the fueling and air upgrades, we cannot go any further. HP levels on the street legal tuning will stay where it is at, as we feel we have found the balance of a good HP increase and not causing problems to the emissions equipment.
Thanks!
H&S Tech is offline
post #10 of 17 Old 10-19-2011, 11:36 AM
Glad to be here, we are here to provide a product that you can be proud of on your new truck!
H&S Tech is offline
