H&S Mini Maxx Tune Why only seeing 23lbs? - Ford Powerstroke Diesel Forum
post #1 of 9 Old 10-16-2011, 08:18 PM Thread Starter
TXGold's Avatar
I have a 2011 F250 6.7 and my software was until tonight(hasn't been installed on the truck yet) SW6.7.13, but have updated it to 6.7.15.
I read in several threads people are seeing 30+lbs. I wasn't that impressed with the tune from the beginning and after a day or two I noticed the tune is only putting out 23lbs, which may even be what stock was doing. It was hard to see boost with the small analog gauge on the dash. Maybe I don't even have a tune installed?
BTW Should I have a power wire going into the fuse box? I don't understand what that would do more for me over the OBDII powering the tuner.
Also, my Pyro reads around 165 when on the road. Did the shop not hook a probe up correctly?
TXGold is offline
post #2 of 9 Old 10-16-2011, 08:35 PM
grmreaper's Avatar
Is this DPF on or DPF off tuning?
That power wire i have tied into my #3 upfitter switch so my H&S turns off with the truck.
For the pyro, that seems quite low to me, but i have no installed my pyro yet.
2011 F350,CC,LB,Lariat,4x4,FX4,6.7L
2.5" Leveling kit - H&S Tuned and DPF bye bye
6k 55W Bi-xenon Morimoto Mini (H1) Projectors and HID fog lights
18x9 Fuel Hostage Black and Brushed wrapped with 325/65/R18's
JL audio 900/5 AMP, JL CleanSweep, JL 13TW5 sub
Waiting to be installed: EGR delete
On order: S&B intake - now 9 weeks and counting
grmreaper is offline
post #3 of 9 Old 10-16-2011, 09:05 PM Thread Starter
TXGold's Avatar
DPF present
2014 Ram 2500 MC Limited Black/Black, 295/65R20 Toyo AT2Ext's, Thuren 2.5 Springs, Fox/Thuren 2.0 ITP Shocks
TXGold is offline
post #4 of 9 Old 10-16-2011, 09:24 PM
6.0L Stroker's Avatar
My pyro 1 reads around 200-300 I believe. It is usually higher right after startup then cools off a bit after driving. My pyro 2 however can be anywhere from 350 to around 800. I am using factory ford sensors dpf present.
2011 F350 CC/SB Bronze and Gold KR tinted windows, spray in bedliner. MBRP 5in filter back with 6in tip and Mini Max. S&B Dry Intake, TGC Dual Stabalizer.
Sold 2004 Ford F-350, cc/lb Lariat, Procomp 6.5 lift with 37/13.5/17 Toyo Mts, Id tuned Ficm, Bully Dog Triple Dog, MBRP all the way back,
6.0L Stroker is offline
post #5 of 9 Old 10-17-2011, 02:44 AM
matty21's Avatar
That's unusual, should be higher. Is that what it shows for your recorded peak?
I just use the OBDII plug with the cable ran inside the dash.
As for egt's, idle I see 260-280 and highway is around 550-650 but at full throttle it will go too 13-1400*F best place to monitor is the H&S egt kit. But your set up on the wrong pyro that's why your not seeing proper temps.
2015 F350 King Ranch
monochrome tuxedo black, every possible option.
Ordered April 30, 2014
Yet to be delivered
2011 F350 KingRanch 6.7L
AFE stage 2 intake
H&S tuner 4" straight pipe
dual 6" MBRP black stacks. DPF, DEF, EGR Delete
ZEX NOS kit with .088 jet
08 Harley Davidson F350
6" lift with 36x15.50x20's
spartan tuned and deleted.
matty21 is offline
post #6 of 9 Old 10-17-2011, 06:58 AM Thread Starter
TXGold's Avatar
I just updated the software to the latest 6.7.15 and it does boost more, I'm seeing a peak of 26psi. I need to get on the freeway and stretch it's legs and see if it reads any higher.
This also may be a function of the atmospheric conditions down here in muggy Houston. We will see cold temps on Wednesday so maybe I'll see a constant 30psi then.
This software is very ambiguous. I came from the Porsche Turbo world where the information on the tune are all over the internet. One tune may be based on timing and another may get its power from boost. There is ZERO information on how these tunes operate or what kind of boost you should be seeing and even more unimpressive is the lack of checking for lean conditions. I'm not sure if it's cause a diesel is less affected by lean conditions because of the way they operate but if its like i suspect it would be almost a necessity to see how lean the engine is running with the new tunes, or if injector duty cycle is maxed out or what.
TXGold is offline
post #7 of 9 Old 10-17-2011, 09:03 AM
matty21's Avatar
They won't build boost unless you load it
Yet to be delivered
AFE stage 2 intake
matty21 is offline
post #8 of 9 Old 10-17-2011, 10:19 AM
And lean or rich has nothing to do with the way a diesel opperates. I understand what you are aying as I had an Evo with a built 2.3 and a Magnum SRT-8 that was built, but a diesel controls the power through fuel, not air. That is a very basic statement, but there is a very basic difference. Actually, if a diesel is running rich i.e. stuck injector then that is BAD. Lean = safe with a diesel, rich = bad. Exact opposite of gas.
joeycoates is offline
post #9 of 9 Old 10-17-2011, 11:50 AM
matty21's Avatar
Very true. I guess I should have said I'm running out of fuel haha
Yet to be delivered
AFE stage 2 intake
matty21 is offline
