AFE stage 2 si and check engine light - Ford Powerstroke Diesel Forum
post #1 of 37 Old 10-08-2011, 11:25 AM Thread Starter
Anyone run into this?
I have only 2000 miles using the intake and the check engine light keeps coming on.
Took it to Ford and they said it is due to the intake, everything else is fine.
Any suggestions?
kwak12r is offline
post #2 of 37 Old 10-08-2011, 11:31 AM
mazsecond's Avatar
Feedback Score: 4 reviews
You would need to scan the PCM and see what code its throwing. If your not running a tuner you it could be just a misreading from the MAF sensor because your pulling in more air. A tuner would solve that problem. Give us some codes and we can help.
Mike
mazsecond is offline
post #3 of 37 Old 10-08-2011, 11:34 AM
harrysmith500's Avatar
I'm staying tuned. I hope AFE would have stated potential issues like this. I've got a stage 2 sitting in the box still.
HBS
Duratrac's FTW
2012 F-250
From the Beehive State
harrysmith500 is offline
post #4 of 37 Old 10-08-2011, 11:49 AM Thread Starter
Thanks for the quick reply.
Ford cleared the code but did not tell me what the code was, just that it related to the MAF and the intake pulling more air.
They also proceeded to lecture me about not doing any modifications to the truck as the will find any way to void the warranty. I guess the 6.4L costed them a lot! SO....i have not put a tuner on this truck.
I called AFE and they are going to ship me a new intake tube to try out. They thought this might be an answer but not really sure. They also feel that the MAF is sending the code as it is reading too much airflow. I guess i will see once i put the new tube on.
kwak12r is offline
post #5 of 37 Old 10-08-2011, 11:54 AM
Retired
Sgt93's Avatar
The code should be listed on your receipt from the service.
2015 Ford F350 King Ranch SRW SB 4x4 loaded, RetraxPro, Andersen Rapid Hitch.
Ordered: 04/29/14
Built: 05/20/14
Delivered: (projected 06/04/14)
2013 Jeep Rubicon Unlimited
SOLD 2011 Ford F250 Lariat 6.7 PS CC 4x4 SB 3.55 with a bunch of crap.
Sgt93 is offline
post #6 of 37 Old 10-08-2011, 01:26 PM Thread Starter
Went back to Ford to clear the code.....again.
Code is P2073 MAP/MAF-TP: Correlation at idle.
Mechanic said it is the AFE so i am hoping that the new intake tube that AFE is sending me solves the problem.
kwak12r is offline
post #7 of 37 Old 10-08-2011, 02:21 PM
mazsecond's Avatar
I;m not very familiar with the 6.4 but on the 6.0 I know that the stock air intake and filter are the best setup until you go past 500HP. Nothing can filter the air as good while still delivering the airflow of the stock Donaldson filter. Maybe the 6.4 is different but just a thought. I'd love to put an intake on my 6.0 but I won't cause I know it'll eventually hurt my turbo.
Mike
post #8 of 37 Old 10-08-2011, 05:53 PM
Retired
Sgt93's Avatar
I had a CEL last winter on for 4 months or so. 3-4 trips to the dealer and it needed a new sensor and Nox box due to intake (stock). That's what scares ne about changing to a different intake.
Ordered: 04/29/14
Built: 05/20/14
Sgt93 is offline
post #9 of 37 Old 10-08-2011, 07:17 PM
grmreaper's Avatar
Just throwing it out there, is this a wet or dry AFE? if its a wet, is it possible oil got on the MAF so just needs to be removed and cleaned?
2011 F350,CC,LB,Lariat,4x4,FX4,6.7L
2.5" Leveling kit - H&S Tuned and DPF bye bye
6k 55W Bi-xenon Morimoto Mini (H1) Projectors and HID fog lights
18x9 Fuel Hostage Black and Brushed wrapped with 325/65/R18's
JL audio 900/5 AMP, JL CleanSweep, JL 13TW5 sub
Waiting to be installed: EGR delete
On order: S&B intake - now 9 weeks and counting
grmreaper is offline
post #10 of 37 Old 10-08-2011, 09:37 PM
First 6.7 PS Destroyer
mysticblu999's Avatar
Quoted: 2 Post(s)
Let us know how the new tube works
2011 F250 6.7 4x4 CC Lariat
6" 4-link BDS
22" Fuel Hostage
37" Toyo MT
H&S BLACK MAXX,
5" MBRP straight pipe
AMP Steps
Truck pics ---->
mysticblu999 is offline
