loss of mileage with cold air intake? - Ford Powerstroke Diesel Forum
post #1 of 10 Old 09-07-2011, 12:15 PM Thread Starter
I've done some reading and it seems that almost everyone that have change intakes has lost mileage. I wanted to get the airaid but I saw a guy say he lost 2 mpg with it. Is this really happening to all brands if so doesn't it seem the aftermarket kit is hurting your truck. More air should mean better combustion resulting in more power and less fuel burned?
2011 F250 6.7 Lariat Ultimate FX4 CC Tuxedo Black Tan Bottom
stroke11 is offline
post #2 of 10 Old 09-07-2011, 12:58 PM
can someone explain this? it has happened to every truck ive owned gas or diesel. thats why my '11 is stock.
pborgia is offline
post #3 of 10 Old 09-07-2011, 04:11 PM
matty21's Avatar
i dont beleive that. especially with tuning.
but the placement of the MAP does make a difference .
2015 F350 King Ranch
monochrome tuxedo black, every possible option.
Ordered April 30, 2014
Yet to be delivered
2011 F350 KingRanch 6.7L
AFE stage 2 intake
H&S tuner 4" straight pipe
dual 6" MBRP black stacks. DPF, DEF, EGR Delete
ZEX NOS kit with .088 jet
08 Harley Davidson F350
6" lift with 36x15.50x20's
spartan tuned and deleted.
matty21 is offline
post #4 of 10 Old 09-07-2011, 06:44 PM
1st Cold Air Intakes do not bring in more air. More meaning Volume. There are supposedly supposed to bring in "colder air", colder air means better performance which is the reason most high performance cars have intercoolers.
2nd it all depends on the cold air kit. Most performance car cold air kits are a joke. Many of them have chrome pipes (which attracts more heat the the factory plastic) and are open to the engine carpatment where all the engine heat is. Factory air cleaners and pipes are usually aimed or pick up air from behind the head lights or under the fender (where the coldest air is).
3rd What is wrong with the factory set up? All these companies never say anything but cold air kit adds HP and MPGs. They never say why. These new vehicles are so finely tuned and such tight tolerances that taking something off like a air cleaner normally does harm to performance.
If you want to pick up MPGs I would say custom tuning is your best bet.
91Terminator is offline
post #5 of 10 Old 09-08-2011, 06:45 AM
Ryan2011dieselpower's Avatar
Have to agree with 91terminator on this..
Ryan2011dieselpower is offline
post #6 of 10 Old 09-08-2011, 06:58 AM
thank you! makes sense.
pborgia is offline
post #7 of 10 Old 09-08-2011, 07:57 PM
No Problem. I left my 2003 Cobra air intake all stock.
post #8 of 10 Old 09-08-2011, 08:46 PM
So is it alright to leave the stock intake when running a tune?
cthaeffner is offline
post #9 of 10 Old 09-08-2011, 08:55 PM
I dont think it would hurt. Not all cold air kits are bad, there are good designs out there. Will you be able to tell the difference I dont know, but with you tune you will.
post #10 of 10 Old 09-17-2011, 09:00 AM
"Stroker 8"'s Avatar
Quoted: 4 Post(s)
I would keep reading up on the tuners available, I have had several CAI's on past vehicles. I always seemed to pick up some performance (sometimes hardly noticeable other times WOW! However, I never saw the gains in MPG. as some of the companies claimed. Hope this helps. Let us know what ya decide to do. There is a wealth of knowledge on here.
Larry
2015 F-350 CCLB DRW, Lariat Ultimate,
2nd Gen. 6.7L "Scorpion" Turbo Diesel,
440HP/860TQ, Torque Shift 6-speed,
Tuxedo Black W/Charcoal Black Int.,
14,000 LB GVWR,
3:73 Gears W/Limited Slip,
17" Polished Forge Alum. Wheels,
BFG All-Terrain Tires,
Factory 5th Wheel/Gooseneck Prep Pkg.,
Spray In Bed-Liner,
Supplemental Cab Heater,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
Engine Block Heater,
9025 Lbs. on the CAT Scales.
"Mack Daddy Scorpion!"
"Stroker 8" is offline
