6.7 delete question - Ford Powerstroke Diesel Forum
post #1 of 34 Old 09-05-2011, 08:42 AM Thread Starter
LFD132's Avatar
Quoted: 3 Post(s)
6.7 delete question
I am pretty familiar with doing a DPF delete on a 6.4, but I looked at the exhaust on my 6.7 and not sure I Would want to tackle that. What is like and what is involved in doing a delete on these 6.7's? What is that round canister right before the tips on the exhaust?
Steve
[SIGPIC][SIGPIC]2013 F250 FX4
LFD132 is offline
post #2 of 34 Old 09-05-2011, 08:58 AM
matty21's Avatar
its just as easy as the 6.4's.
the round cans are harmonic dampers
2015 F350 King Ranch
monochrome tuxedo black, every possible option.
Ordered April 30, 2014
Yet to be delivered
2011 F350 KingRanch 6.7L
AFE stage 2 intake
H&S tuner 4" straight pipe
dual 6" MBRP black stacks. DPF, DEF, EGR Delete
ZEX NOS kit with .088 jet
08 Harley Davidson F350
6" lift with 36x15.50x20's
spartan tuned and deleted.
matty21 is offline
post #3 of 34 Old 09-05-2011, 09:09 AM Thread Starter
LFD132's Avatar
Quoted: 3 Post(s)
I took a peek under there and it looked like they had shoved more crap underneath and added another section with bolts and flanges. I have all my exhaust from my 6.4. Think it will work on a 6.7?
LFD132 is offline
post #4 of 34 Old 09-05-2011, 12:25 PM
Hawkeye Diesel's Avatar
Removing the Exhaust on a 6.7 to put a straight pipe on is pretty easy! A buddy and I did mine in his garage in about 2 hours or so. The best way to tackle it is to dis connect the flange from the down pipe to the DPF/CAT/SCR, then remove the piece just behind that that connects all that junk to the actual tail pipe. From there, its just a matter of un-hooking sensors, and removing hangers. I wish I had known this helpful bit before I started mine, but as far as removing the hangers goes, just un-bolt them from the frame/body and drop the whole piece as one, you'll want to use a floor jack and a friend, as the DPF/CAT/SCR is HEAVY! Then just take the couple of hangers you need off all that and re-install them to hang your straight pipe.. I took the time to pry all the rubbers loose rather than just unbolting everything, which took for ever. The only bad part is, all the connectors are different types of plugs, and if you had your truck undercoated, they're a ***** to get apart. There is one plug that is attached to the exhaust hanger itself, I broke that plug, so be careful. Otherwise its pretty straight forward and easy!
[/SIGPIC]2008 F250 Lariat, 8" lift 37x12.5 20 Nittos, Spartan tuned running 275 with an AFE stage 2 and 4" straight pipe. Next up, full EGR and Cooler delete
Proud to be a Union Steamfitter
Hawkeye Diesel is offline
post #5 of 34 Old 09-05-2011, 12:49 PM Thread Starter
LFD132's Avatar
Quoted: 3 Post(s)
Thanks for the info. I swore I wouldn't tune this truck until the warranty was out. Not so sure I can hold out that long lol. I sold my tuner so it will definitely be a while before I start down that road again. Truck is pretty impressive stock.
LFD132 is offline
post #6 of 34 Old 09-05-2011, 05:09 PM
I swore up and down I wouldn't tune mine either, but a buddy of mine with a 6.4 thats H&S tuned was showing off and that pretty much made my decision right there! I loved the truck stock, I loved the truck with the mini and the DPF On tunes, and I love the truck now with the DPF Delete tunes..
post #7 of 34 Old 09-06-2011, 07:56 AM
DSTRBD's Avatar
As previously stated, the install is pretty straight forward and not much more difficult than a 6.4L. It can be handled by the average do-it-yourselfer in a few hours time, tops.
ICON Vehicle Dynamics | S&B Intakes | MBRP Exhaust | American Force Wheels | Diamond Eye | AFE Intakes | Carli Suspension | Industrial Injection | Garrett Turbos | FASS | Method Wheels | Bilstein Shocks | Airdog | KMC Wheels | Spartan | RSouth Bend Clutch | SCT | Edge Products | ATS Diesel | Bullydog | BMF Wheels | AMP Research | & much more....
DSTRBD is offline
post #8 of 34 Old 09-08-2011, 07:48 AM
Was there any MPG gains doing the tune and delete? Just asking because it seems like the 6.7 are getting respectable fuel millage from factor. Thanks
carls4wd is offline
post #9 of 34 Old 09-17-2011, 09:05 AM
"Stroker 8"'s Avatar
Quoted: 4 Post(s)
Toates...very Respectable MPG stock. this is One reason I'm staying stock till I can do more research.
Larry
2015 F-350 CCLB DRW, Lariat Ultimate,
2nd Gen. 6.7L "Scorpion" Turbo Diesel,
440HP/860TQ, Torque Shift 6-speed,
Tuxedo Black W/Charcoal Black Int.,
14,000 LB GVWR,
3:73 Gears W/Limited Slip,
17" Polished Forge Alum. Wheels,
BFG All-Terrain Tires,
Factory 5th Wheel/Gooseneck Prep Pkg.,
Spray In Bed-Liner,
Supplemental Cab Heater,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
Engine Block Heater,
9025 Lbs. on the CAT Scales.
"Mack Daddy Scorpion!"
"Stroker 8" is offline
post #10 of 34 Old 09-18-2011, 12:05 PM
my MPG averaged between 15 and 16 mpg a tank, with mostly in-town stop and go driving and usually 2 re gens per 26 gallons of Diesel, and on the open highway full trips, I averaged 18 w/1 regen per 26 gallons of diesel. Since the Delete, I am averaging 18 mpg per tank with mostly stop and go driving, and on the few small trips I've taken to Iowa City I get a little over 20 mpg.. all this is Hand Calculated.
I will be driving 1100 miles to Austin Texas this week, so I will be sure to watch my MPG per tank on the way there and on the way back, and will re-post next Monday when I get back to Iowa.
Also, these numbers are all based on keeping my tuner on set on "WILD" when the DPF was on, and also now that the DPF is deleted...
