Tuner Footprints - Ford Powerstroke Diesel Forum
post #1 of 6 Old 08-02-2011, 05:45 AM Thread Starter
Lobos's Avatar
Tuner Footprints
Hi Guys, I have read several threads on this issue and understand that when tunes are applied to the ECM, you cannot removed all traces of the tune. I had an 06 with an Edge Attitude II. The way it installed it appeared to me the ECM was "jumped" with their wiring harness to a module supplied with the monitor.
Having said all that, does a setup like this leave footprints? http://www.powerstroke.org/forum/ima...lies/dunno.gif
2011 Ford F250 (Named Hagar) Royal Red Metallic w/ Adobe Int, 40/20/40, 4x4 Lariat CCSB, NAV, 6.7L PSD, 3.55 w/ elock.
Lobos is offline
post #2 of 6 Old 08-02-2011, 06:31 PM
Jesse@MBRP's Avatar
My dealer was unable to see any footprint of the Innovative module.
Jesse Rohr - MBRP Performance Exhaust
email -
Become an MBRP fan on Facebook
Jesse@MBRP is offline
post #3 of 6 Old 08-03-2011, 07:29 AM Thread Starter
Lobos's Avatar
Do you know if the system Edge used for the 06 would work o the 6.7? If doable, wouldn't this ease concerns with warranty issues for those that want to remove the DPF for better mileage?
Lobos is offline
post #4 of 6 Old 08-03-2011, 07:31 AM Thread Starter
Lobos's Avatar
What I should have said, Would the use of a "jumped" module with the tune be a solution?
Lobos is offline
post #5 of 6 Old 08-05-2011, 07:49 PM
Dim Sum's Avatar
Send a message via AIM to Dim Sum
I highly doubt the 6.7 was built without easy to find parameters that Ford can see to help determine if a tuner was on the truck.
Just doesn't make sense with today's technology not to build in plenty of avenues to detect any tuning.
The real question is...will your dealer look / care? We know that many don't with the 6.4, but if you blow an engine up, Ford will send an engineer and at that point the warranty is up in the air.
-Steve
2011 F-350 Lariat 4x4 SuperCew: White Platinum Tri-Coat, Goodyear Wrangler Silent Armors, Window Tint
2001 Hyundai Elantra: Daily Driver
2007 Polaris Sportsman 700: Weekend fun!
Dim Sum is offline
post #6 of 6 Old 08-15-2011, 03:14 PM
First 6.7 PS Destroyer
mysticblu999's Avatar
Quoted: 2 Post(s)
Sure won't
2011 F250 6.7 4x4 CC Lariat
6" 4-link BDS
22" Fuel Hostage
37" Toyo MT
H&S BLACK MAXX,
5" MBRP straight pipe
AMP Steps
Truck pics ---->
mysticblu999 is offline
