My new TORQ2 having problems!? - Ford Powerstroke Diesel Forum
post #1 of 29 Old 07-23-2011, 09:14 PM Thread Starter
I recieved my new torq2 yesterday. Man, I was pumped up. So much that I couldnt wait for my engine to cool before installing (not a good idea). Anyways, I got it installed. No problem. Turned the knob clockwise to the highest setting and took it for a spin. I could feel the power increase as soon as I gave it gas. I cruised around not getting on it, but could still feel its added power. Today, i actually took it out and drove around town. I gave it full throttle from about 20 MPH felt good until 40 MPH then it kinda stumbled but recovered. Then when I got to 60 MPH it just fell on its face, a complete loss of power and never recovered power. I would just have to let out of the gas. Tried it a few more times with the exact same results. So, I adjusted the knob to the lowest setting, then it ran fine, flooring it well past 60 were it was falling on its face before. I kept adjusting the knob up with no problems until I would adjust it anywhere past half way on the knob and it would start doing the same thing, complete loss of power at 60 MPH. Man, this sucks!!!!
Has anyone running the TORQ2 had a similar issue?
Micheletti is offline
post #2 of 29 Old 07-23-2011, 09:24 PM
roary's Avatar
Do you have any gauges? It could be that maybe your EGT's are getting too high. But if you don't have gauges it's kind of hard to tell.
2003 XLT CCSB
6.0 Auto 3.73
5500k HID 55w DDM Kit
Gryphon with Custom Tunes
65hp Light Tow
80hp DD
120hp Race
140hp Extreme
Check out PHP
if you are interested!
roary is offline
post #3 of 29 Old 07-23-2011, 09:29 PM
mor4wd's Avatar
It's just the TCM doing it's job. Mine does the same thing. The TCM is told only to allow a certain amount of torque and HP into the tranny before limiting it. This is the exact thing that the tuner companies were having so much trouble bypassing when the engine first came out. I've just been staying out of the pedal when the RPMs are nearing the top of gears 1-4. It doesn't seem to have any problem at full throttle in 5th or 6th. One thing; when and if you tow anything, make sure to turn it all the way down. It really stall out a lot when you're towing on full power.
2011 F350 Lariat SRW Crew Cab Long Bed 4x4 6.7 H&S Mini Maxx DPF Delete EGR Delete running 265/70/19.5's
Originally Posted by magzne1 View Post
Chevy comercials are like OBAMA, ALL B.S. over promise and under deliver
Originally Posted by trevor73402 View Post
This stuff isn't as simple as tuning your TiVo to record your Jerry Springer re-runs while your out cruising Wal-mart parking lot for transexual hookers.
mor4wd is offline
post #4 of 29 Old 07-23-2011, 09:41 PM Thread Starter
Whats the point of having a power adder that you have to stay out of the throttle at certain rpm's. I hope thats not the answer!
post #5 of 29 Old 07-23-2011, 10:12 PM
mor4wd's Avatar
That is the answer. It's also in the installation manual that came with the Torq2 (first page). I didn't buy it for the power, it's already got plenty of that, I bought it for potential MPG increase.
mor4wd is offline
post #6 of 29 Old 07-24-2011, 08:40 AM
Mine does it too. It is pretty aggravating. It always does it during a shift and if you don't let out of the pedal when it does it, the tranny will never go ahead and shift. It doesn't do it all the time though. You never know if you should pull out in front of traffic or not because it might fall on its face going into 2nd gear. I wonder if the MP8 has the same symptoms?
cthaeffner is offline
post #7 of 29 Old 07-24-2011, 09:45 AM
Same issues happened with mine. Did it multiple times when turning off of a main highway onto a secondary. Would shift 3 to 4th and then it would have no power. Then the transmission would jump to 5th. No power again when stepping on the accelerator then it shifted to 6th and no power again. I had to put it in M and drop it back to 3 to get going again. Terrible issue when on a highway. Also my Torq2 didn't come with a manual just the unit and wiring in a box. Not very impressed with it at all. And ever since ive takin it out Ive had basically no tranny issues
Current Rig: 2011 F-350 CCSB Lariat chrome FX4 Tuxedo Black.
Mods: aFe stage II, 8000k HID. 6" 4link Skyjacker Lift, 37" Toyos Wrapped around 20x9 XD MisFit Rims, H&S Minimaxx, 5" FloPro straight pipe
Traded: 2006 F-350 CCSB Amarillo Edition
Mods: 6" BDS 4-Link Lift Kit, 4" MBRP Cool Duals Exhaust, AFE Intake, Edge CTS Evo, 37x13.5x20 Toyo MT wrapped around XD Spy 20x9 Rims
UA Local 488 Steamfitter/Pipefitter
AlbertaStroker is offline
post #8 of 29 Old 07-24-2011, 09:58 AM Thread Starter
Well today I was driving down the tollway feeder at a constant 45 MPH and it just started stumbling. I had to slow down to about 15 MPH before I could get it to re-gain power. Then I catch a red light. When I take off, I get to about 10MPH and it loses complete power and never would re-gain it. I had to pull over on the tollway feeder and open my hood and turn the knob all the way down, just so I could continue to drive home. Not good saying that the speed limit was 55 and everyone was flying past me and honking and there's no shoulder on that road.
post #9 of 29 Old 07-24-2011, 01:56 PM
subscribed
2011 F-350, 5% on sides back and eyebrow-35% on windsheild, B&W hitch, Weather Tech mats, Tailgate Assist, Hornblaster Conductor Special 240, Toyo M/T 35", Incubus Krawler 20x9, 2.5" ready lift stage 3.
cdrracing is offline
post #10 of 29 Old 07-24-2011, 02:12 PM
mor4wd's Avatar
It sounds like you guys are having a lot more trouble with yours than I am with mine. Have you opened the box up to turn the dip switches down. There's three switches inside that sequentially turn the power down. With them all off it's at a stock setting. The manual says that if you're having problems try flipping the switches progressively lower until you have no more problems.
mor4wd is offline
