from stock to 35" tires sensors suck - Ford Powerstroke Diesel Forum
post #1 of 23 Old 04-25-2011, 07:58 PM Thread Starter
Joe 6.7's Avatar
I wanted to see If there is anything I can do about the sensor reading low pressure on my tires. I have 35" tires and diffrent rims they put the sensors back in but the pressure is different in the mud tires. Do you guys know of any way to reset the sensors to match the rating of the mud tires?
Joe 6.7 is offline
post #2 of 23 Old 04-26-2011, 06:54 AM
I think one of the tuners allows you to set the pressure now, I think it was H&S.
zsommer79 is offline
post #3 of 23 Old 04-26-2011, 12:16 PM
InMotionJosh's Avatar
Yup, H&S. You will need to try and get your tires up to 65 psi or so to get the sensors to stop flashing the warning unless you get one of the H&S Tuners
2013 CCSB Lariat Ultimate
H&S/AmpResearch/FloPro/MBRP/Recon/AFE More To Come
InMotionJosh is offline
post #4 of 23 Old 04-26-2011, 01:06 PM
Dieseldawg2010's Avatar
Another great reason to get a tuner!
New:
2012 F-350 Lariat CC LB 6.7L 3.55 gears w/E-Loc, Lariat Interior Package, Moonroof, FX4
Air Train Horns/4.5" Carli Starter System/Carli High Mount Stabilizer/XD Rockstar II Matte Black 18x9 5" BS/37x12.50x18 Pro Comp Xtreme AT's/2WD Chin Spoiler
Gone May 2013:
2011 F-250 KR CC SB 4x4 6.7L 3.55 gears Nav System
Gone Feb. 2011:
2004 6.0L, F350 CC 4x4, 10" Icon Lift, 4.56 gears, lockers, Moto Metal 20" wraped in 38" MT's
Dieseldawg2010 is offline
post #5 of 23 Old 04-26-2011, 07:13 PM
mor4wd's Avatar
I don't understand the point of having a truck that can tow as much as ours can, and then putting tires on it that can't handle the load. Why didn't you get load range E tires. They have them in 35's?
2011 F350 Lariat SRW Crew Cab Long Bed 4x4 6.7 H&S Mini Maxx DPF Delete EGR Delete running 265/70/19.5's
Originally Posted by magzne1 View Post
Chevy comercials are like OBAMA, ALL B.S. over promise and under deliver
Originally Posted by trevor73402 View Post
This stuff isn't as simple as tuning your TiVo to record your Jerry Springer re-runs while your out cruising Wal-mart parking lot for transexual hookers.
mor4wd is offline
post #6 of 23 Old 04-26-2011, 08:38 PM
sagebel's Avatar
Quoted: 8 Post(s)
The Trail Grapplers I have are load range E and have a max inflation of 65psi.
2012 F350 DRW King Ranch FX4
Originally Posted by nighthawk285 View Post
Pull it sideways back and forth....and don't be gentle
Originally Posted by Six0~Stroker View Post
I was just planning on running over here and whipping it out. Sent from
sagebel is offline
post #7 of 23 Old 04-26-2011, 09:03 PM
Quoted: 13 Post(s)
The floatation type tires run at 65psi, even though they are E rated.
But the E rating on a floatation tire equals a much lower load capacity.
Mor4, Some folks perfer the floatation to the load capacity. Not everybody puts a load on their trucks like we do. 35x12.5r20 is a 35" tall E rated tire that max's at 65psi. It's rated @ 3195 lbs
Where as the Light Truck non floatation tire. LT295/65R20 is 35.5" tall and runs at 80 psi and is rated 4080 lbs That extra 15psi of air pressure = 900lbs more load per tire.
Painted Horse is offline
post #8 of 23 Old 04-26-2011, 09:40 PM
Mod Newbie
dhanna6powerstroke's Avatar
Quoted: 19 Post(s)
Throw all 4 sensors in a metal pipe, cap both ends with a way to add air, pressurize to 65 PSI. Abracadabra, no more light.
dhanna6powerstroke is offline
post #9 of 23 Old 04-27-2011, 06:51 AM
mor4wd's Avatar
It won't work. The sensors turn themselves onto a standby mode when they don't sense the rotation of the tires. People have tried every way to get around this. The only ways are A)Run tires with a max PSI of 80 B)Put some black tape behind the dash covering the light C)Tuner
mor4wd is offline
post #10 of 23 Old 04-27-2011, 09:37 AM
Mod Newbie
Quoted: 19 Post(s)
Is it hit and miss? My buddy did it on his 08 and never had a light come back on.
