leveling kit questions - Ford Powerstroke Diesel Forum
post #1 of 3 Old 12-23-2010, 06:42 AM Thread Starter
my buddy put a leveling kit on his 2011 f250 and the rear sits about a 1" lower that the front now. someone told him that he can get blocks off a f350 cause they are about a 1" taller than the stock f250 blocks. anyone know about this or know what to do to fix this?
eazymotorsports is offline
post #2 of 3 Old 12-23-2010, 06:37 PM
They sell kits for the f350 blocks with longer u-bolts and the works. But yes that is what he needs to do.
tbaker00 is offline
post #3 of 3 Old 02-26-2011, 05:49 PM
yo there easy motorsports.. i got an 11 f-350 with the 11,500lb springpacks. spent quite abit of time researching before i levelled mine. there is about 3.5" diff between front and back. i installed a 1.5" levelling kit. somehow the diff now is just over 1". but the reason i lifted the front only partway is that if it is level empty then its going to lookand feel over-loaded when you do put anything in the bed or pull trailersor eq like i do. keep the back a little higher for weight capacity...good luck...regards...dc.snowball.
dc.snowball is offline
