H+S 6.7 EGT probe mounting solution, EGR delete - Ford Powerstroke Diesel Forum
post #1 of 14 Old 12-12-2010, 10:10 AM Thread Starter
powerstroker67's Avatar
We have finished production and began shipping EGR block off plates for the 6.7 engines. Installation is very simple, bolt on install using all factory hardware. No drilling or modifications needed, and work should take less than 30 minutes to complete. These plates allow you to install a EGT probe 1/8 NPT into the exhaust manifold without drilling.
ID:	20441   Click image for larger version
ID:	20442   Click image for larger version
ID:	20443   Click image for larger version
powerstroker67 is offline
post #2 of 14 Old 12-13-2010, 05:05 PM
blakeclark's Avatar
How much? I would like to order one.
11 6.7 cc/sb
blakeclark is offline
post #3 of 14 Old 12-14-2010, 10:49 AM
What about drive pressures? Do these things wastegate through the EGR like the 6.4? Just wondering if any damage could occur?
11' F-250 KR FX4
Bone Stock!
SuperStrokin is offline
post #4 of 14 Old 12-14-2010, 01:52 PM Thread Starter
That would be a question for H+S as the EGR function is turned off in the tuning already, so the plates don't affect that at all. These power levels are fairly low right now so I wouldn't think it would be an issue. The plate on the manifold sure gives us a great location to test drive pressure if it was a concern. If these 6.7 prove to be as durable as the 6.4's, drive pressure only really became an issue as the tuning/hp increased in 275 hp + tunes.
post #5 of 14 Old 12-14-2010, 02:35 PM
He is correct. Drive pressure is not much of an issue yet, and I doubt it will be for quite some time. We will try to incorporate a few new PIDs to monitor, including drive pressure, on the BM and MM units. This may be some time down the road, but is for sure on our list of things to get tackled.
Bentley
H&S Tech is offline
post #6 of 14 Old 12-14-2010, 05:03 PM
Sweet, probably wouldn't go much more than the 150 tune anyways. The egr block off plates look really easy as everything is on top of the motor vs. behind the drivers side wheel on the 6.4. Hats off!
11' F-250 KR FX4
Bone Stock!
post #7 of 14 Old 12-18-2010, 07:19 PM
First 6.7 PS Destroyer
mysticblu999's Avatar
Quoted: 2 Post(s)
So there is a good use for the EGR
2011 F250 6.7 4x4 CC Lariat
6" 4-link BDS
22" Fuel Hostage
37" Toyo MT
H&S BLACK MAXX,
5" MBRP straight pipe
AMP Steps
Truck pics ---->
mysticblu999 is offline
post #8 of 14 Old 12-19-2010, 06:46 AM
BALL D's Avatar
i am new to the diesel world what does this or help
BALL D is offline
post #9 of 14 Old 12-19-2010, 08:12 AM
Porthole's Avatar
Is the EGR system in the new engine as detrimental as in the old, and for that matter it was bad in Ford or GM.
I ran 50K miles in my GMC before I had an EGR issue, fixed under warranty after a fight. Then I blocked it off and added a Kennedy Diesel finger stick (stops codes).
Is this “kit" going to be similar?
Will it save me from EGR problems down the road?
Will it cause the PCM to throw codes?
As of now I don’t plan on doing any tuners or HP upgrades. But if this kit was beneficial to engine life and could be prevented from interfering with the PCM I would really be interested.
Where in the system is the EGT probe reading then? Pre or post turbo? EGT gauge is something I would like to add.
Thanks,
Duane
First ever blue oval........
2011 F-350 DRW White Tri-coat
2010 3010 Cyclone Toy Hauler
Porthole is offline
post #10 of 14 Old 12-19-2010, 08:31 AM Thread Starter
It is more of a EGT probe mounting solution as of now, but does remove any possiblity of a failed EGR cooler filling the engine with coolant. It reads PRE turbo EGT in the right side exhaust manifold by hanging the EGT probe into the manifold just forward of centered. It will also reduce the EGR/ intake charger cooler water temps by keep exhaust away from the EGR coolers. This will reduce intake charge temps by not using exhaust to heat the water. These 6.7 trucks have 2 cooling systems function under the hood. One cools the engine as a traditional system and the second cools intake air side of the engine which includes the water to air intercooler and the EGR system. As far as setting codes, yes a stock truck or even truck programmed which the EGR still function will set codes and cause problems.
