So a little background. This is all on an off-road only vehicle btw. I had a 2012 f350 that was fully deleted, so I remember some of the stuff I had to do. I recently bought a 2013 f250 already came with a h&s race tuner in high sulfer mode. The EGR is still on vehicle, butterfly valve on intake unplugged and block off plates installed. The block off plate on exhaust manifold has an EGT sensor in it and that is plugged into engine harness. On the tube from the EGR to the intake, there is an EGT sensor also but is not plugged in at all. (Sounds correct to me for a deleted vehicle, new sensor plugged in where other sensor was plugged in so that the tuner can read EGT's) One of the things that is wierd to me is the orange plug on top of the EGR is still plugged in. (Should be unplugged correct?)
Also all the DPF stuff is still on vehicle and plugged in. The exhaust and all its sensors are all still intact.
One more thing, on the tuner it says, under fuel, it is in high sulfer mode(deleted correct?) But when I click on the emissions tab it says; Unlock successful. Click download to complete install or RESET to complete at a later time. Does this mean it is deleted or not yet? Just seems confusing. I would like to either, know it is deleted or not. Seems kinda halfway if you ask me.
So, is this OK to run this way? Seems to me the orange plug should be unplugged first off, and the dpf and all that should be removed for a straight pipe and that leaving it the way is currently is could cause issues as no Regen cycles will be performed and dpf filter and all that could clog up and be ruined.
Any recommendations?
