Looks like the tube and filter is floating (not supported other than via the silicone fitting). I see no "No Limit" markings on the tube or pipe in back/top/front. Can you snap a pic of yours?
Did you look at the parts before you took it to the shop? As far as I know all the boots have the no limit logo on them. Maybe your shop swapped it out for a less sturdy boot that is bending more than a no limit one would.
Those are our boots. We had a batch made by a different supplier that didn't have the No Limit logo on them. OP you have a simple installation misalignment. Shop just put it in too quick. It needs to look like its following the contour of the degas tank. Yours looks like its stuck up way to high
Just readjusted again and based on the above pics, my boot seems longer and yes pushed all the way to stops. Here is the boot which after words we cut off about 1/4" which is still longer than the above. Pinch seems less. Going to see if this holds structure. Any reason why a longer tube and shorter boot wasn't done?
Had the same problem with my stage 2 nl kit. After an hour and a half of Monkey dicking around, figured out the pipe was in backwards.
Sent from my SM-G930V using Tapatalk
Related Threads
Ford Powerstroke Diesel Forum
5.4M posts
265.8K members
Since 2005
