2016 f250 fully deleted with sct livewire and GH tunes with NL stage 2 intake. Im throwing a code p2182. does anyone have experience with this code on how to fix it?
that would be the secondary cooling ect2 sensor. More than likely its bad if that code comes up and keeps coming up after 8 hr cold soak. There are some test procedures, but you will need forscan or Ford IDS or maybe a decent scanner or tuner that can pull than Temp sensor.
I can also give you the Ohms readings for temperature or the test procedures if you like.
I just find it hard to believe that sensor would go bad. The truck is only 5 months old. Never had a problem with it until after the delete. With only 6500 miles and never a check engine light until after the delete
Related Threads
Ford Powerstroke Diesel Forum
5.4M posts
265.8K members
Since 2005
